ᐅ How can you gently clean IKEA Hemnes furniture when you have pets at home?
Created on: 3 Aug 2024 10:47
Fadyna
Fadyna
3 Aug 2024 10:47
Hello everyone, I am looking for a gentle method to clean my IKEA Hemnes furniture since I have pets at home. It is important to me that the cleaning products used not only protect the surface of the Hemnes series, which is made of wood and lacquer, but are also safe for my cats and dog. So far, I have often just used a damp cloth, but I would like to know if there are any specific tips or home remedies that help clean the furniture without damaging the wood protection or lacquer finish, and that do not pose any health risks to my animals. Does anyone have experience or recommendations on how to clean the furniture gently but effectively—especially when considering pets? Which cleaning products are suitable, and what should definitely be avoided? Thanks in advance for your tips!
Jensson
3 Aug 2024 14:12
Hello Fadyna,
You have asked a very important question, especially when there are pets in the household. When cleaning furniture like the IKEA Hemnes series, it is essential not to use harsh methods or strong chemicals.
Here is a brief guide on how you could proceed:
- Initially, cleaning should generally be done with a soft cloth slightly dampened to remove dust and light dirt.
- For tougher stains, it is best to use a mild soap solution (e.g., a few drops of pH-neutral dish soap in warm water) and test it first on an inconspicuous spot.
- Make sure to wipe the furniture thoroughly with a dry cloth afterwards, so no moisture penetrates the wood or finish.
- Avoid aggressive cleaners or solvents such as alcohol, ammonia, or bleach; these can damage the protective layer and are also harmful to pets.
- To protect the surface, you can also use natural products like special furniture waxes based on beeswax. These are usually safe for pets.
- It is also important not to leave any cleaning products open where animals could lick them.
Summary: Use mild, pH-neutral cleaning agents, avoid harsh chemicals, always dry thoroughly, and rely on natural waxes for protection. If you follow these points, you should be able to protect both your furniture and your pets.
If you like, I can also provide some product recommendations that I use myself.
neoren
4 Aug 2024 09:02
Jensson schrieb:
For stronger dirt, it’s best to use a mild soapy solution (e.g., a few drops of pH-neutral dish soap in warm water) and test it first on an inconspicuous area.
I can confirm this. Plain water with mild soap is usually enough; no need for harsh cleaners. Important: do not use soaked cloths.
Ramon4
5 Aug 2024 18:33
Fadyna schrieb:
Does anyone have experience or recommendations on how to clean furniture gently but effectively – especially when you need to consider pets?
I have two cats myself and mostly use microfiber cloths on my Hemnes furniture, as they pick up dust and light dirt very well without needing any liquids. For tougher stains, I recommend a mild soapy solution, as mentioned, followed by thorough wiping with clean water.
When cleaning around pets, it’s important to avoid products containing fragrances or harsh chemicals, as many animals can be sensitive to these. Often, simply removing dust and pet hair regularly is enough to keep the furniture looking fresh.
One more tip: depending on how often your dog or cats use the furniture, you can also use special furniture covers or throws. This helps prevent scratches and residue, which you can then clean more easily without constantly stressing the original wood.
In summary: gentle cleaning, mild products, regular maintenance, and preventive protection measures are the best way to care for Hemnes furniture in a pet-friendly manner.
