ᐅ How sturdy are IKEA Brimnes furniture pieces when assembled and disassembled frequently?
Created on: 15 Nov 2022 19:23
Amarga
Amarga
15 Nov 2022 19:23
I am currently considering buying some IKEA Brimnes furniture but am a bit uncertain about its durability, especially with frequent assembly and disassembly. I plan to take the furniture apart and reassemble it regularly, for example when moving or if I want to reposition it. My specific question is: How stable and resilient is IKEA Brimnes furniture with frequent assembly and disassembly? Are there particular weak points I should watch out for, or materials that tend to wear out more quickly? I would appreciate any experiences or recommendations on how to maintain stability over a longer period.
EDWARD0
15 Nov 2022 20:07
The Brimnes furniture is generally sturdy, but frequent assembly and disassembly can lead to loose joints. Screws and dowels may wear out more quickly. It is advisable to tighten the screws after each assembly.
tra_nina
16 Nov 2022 07:35
Regarding the durability of IKEA Brimnes furniture with frequent assembly and disassembly:
- The construction is mainly based on particleboard with wood veneer, which is more prone to damage from repeated disassembly compared to solid wood.
- The metal fittings and connectors are reliable, but repeated assembly and disassembly can cause wear and less precise joints.
- Special attention should be paid to the anchoring of the back panels and the connection of the side panels during each assembly.
- Maintaining the screws is important to prevent wobbling or material fracture.
Overall, this furniture series is better suited for permanent installations. If frequent moves or reassemblies are expected, the use of assembly adhesive or hardwood dowels can be recommended to improve stability.
anfeteo
16 Nov 2022 14:42
I have personally assembled and disassembled Brimnes furniture multiple times during several moves and can share some practical tips:
- With frequent assembly and disassembly, the connection points, especially the so-called Minifix screws, are the weak spots. These should always be handled carefully and not over-tightened.
EDWARD0 schrieb:
You should tighten the screws after every assembly.
This is absolutely correct. I retighten all connections after each assembly.
- Use the right tools: A cordless screwdriver with adjustable torque settings prevents damage to the screws.
- Avoid applying excessive force during assembly, as particleboard is particularly vulnerable.
- If the connection holes become enlarged, fill them with wood filler and pre-drill new holes to maintain stability.
Summary: Brimnes furniture can withstand frequent assembly if you work carefully, check the screws regularly, and avoid overtightening.
Katan
17 Nov 2022 11:11
Hey Amarga,
“How stable is IKEA Brimnes furniture with frequent assembly and disassembly?” — that’s actually a very important question, especially if you move often or want to stay flexible. I’ve moved and reassembled my Brimnes dresser several times now, and as long as you take your time, avoid over-tightening screws, and handle it gently, it holds up quite well!
anfeteo schrieb:
Use the right tools: A cordless drill with torque settings prevents damage to the screws.
I can fully agree with that.
One more tip: If you wipe the parts with a damp cloth before assembly and lightly lubricate the screws, the process goes much smoother. And hey, who says furniture can’t use a little care? 😉
My conclusion: Brimnes performs well with careful handling, even though, of course, it’s not solid wood.
