ᐅ How long do IKEA BRIMNES furniture pieces typically last?
Created on: 6 Jul 2024 19:23
Nikau
Nikau
6 Jul 2024 19:23
I am currently considering purchasing some furniture from the IKEA Brimnes series but am unsure about the average lifespan of these pieces. Specifically, I’m interested in how long the Brimnes furniture typically lasts when used normally in a private household—with everyday use such as opening drawers or doors daily, occasional rearranging, and regular cleaning.
Are there any experiences regarding how long one can expect stable functionality and an acceptable appearance under typical use? Do these pieces often become unstable or unattractive after just a few years, or do they tend to last longer?
I also want to avoid having to replace the furniture quickly, as sustainability and costs are important factors to me.
Who can share their long-term experiences or reliable information on how durable Brimnes furniture is under realistic household conditions? Thanks in advance for your assessment!
ju_ren
6 Jul 2024 20:04
BRIMNES typically lasts 5 to 8 years under normal use. The construction is solid for the price but not suitable for heavy loads or rough treatment. If you are very careful, it can last up to 10 years, but you shouldn’t count on that. It is important not to overload the furniture and to regularly tighten the screws.
warrenka57
7 Jul 2024 07:47
ju_ren schrieb:
BRIMNES usually lasts 5 to 8 years with normal use.
That’s basically a realistic assessment, in my opinion. I have had a BRIMNES chest of drawers in my bedroom for 6 years. At first, I was very satisfied, but since last year I’ve noticed the drawers becoming a bit harder to open and the surface showing minor signs of wear. Still, the piece of furniture gives me a good sense of stability and functionality.
I know exactly what you mean when you say not to overload it. In the beginning, I sometimes packed too much in, which affected both the appearance and the material. You just learn over time to be more patient and careful.
I’m curious whether others have had similar experiences or if some BRIMNES furniture lasts even longer. Ultimately, there are differences depending on the model and usage – but 5 to 8 years seems like a fairly reliable estimate, although that naturally also depends on maintenance.
fredle
8 Jul 2024 12:39
Hello Nikau,
I would like to answer your question a bit more systematically, based on my extensive experience with IKEA furniture, including the BRIMNES series.
1. Material and Construction:
- BRIMNES is mainly made of particleboard with a melamine finish. This type of construction is sturdy but not comparable to solid wood furniture.
- The coating protects against moisture and scratches, but if moisture penetrates over a longer period, the material can swell.
2. Average Lifespan:
- With normal, careful use, BRIMNES furniture is often used for about 6 to 9 years before noticeable serious damage appears.
- The main wear points are typically the hinges, drawer slides, and edges, which are stressed by frequent use.
3. Care and Handling:
- The lifespan can be significantly extended by regularly checking screws and treating the surfaces gently.
- Avoid standing moisture and overloading the drawers heavily.
4. Long-term vs. Short-term Use:
- BRIMNES furniture is well suited as a temporary solution or for rental apartments.
- If you are looking for a long-term investment with high durability and excellent robustness, you should consider more robust product lines.
Summary:
BRIMNES furniture can easily last 6 to 9 years with good care, often longer if it is not heavily stressed. The price-performance ratio is quite good. If you use specific pieces more frequently (e.g., wardrobes or beds), pay attention to care and handling to enjoy the furniture for a longer time.
If you have any further questions about care or specific furniture items, I am happy to help!
