ᐅ How can IKEA Brimnes furniture be transported safely and without damage?
Created on: 5 Aug 2020 08:37
PUMAXIMO53P
PUMAXIMO535 Aug 2020 08:37Hello everyone, I plan to safely transport some IKEA Brimnes furniture pieces (including wardrobes and dressers) without any damage occurring during the journey. Since these pieces are usually quite large and sturdy but also have delicate surfaces, I am interested in proven methods you use to specifically prevent damage during transport.
I am thinking, for example, about proper packaging, padding, handling during loading, and the transport process itself. Are there any special recommendations regarding whether to disassemble the furniture, how to secure the individual parts most safely, and which materials work best to prevent scratches, chips, or deformations? I look forward to your tips and experiences!
In general, I recommend the following approach for IKEA Brimnes furniture:
- Disassemble the furniture as much as possible into individual parts. This reduces unnecessary stress and allows for easier handling.
- Use thick blankets or special padding mats to cover surfaces and protect them from scratches.
- Secure the parts in the vehicle with ratchet straps to prevent shifting.
- IKEA boxes are often already well-fitted; spare or custom-made protective structures made of corrugated cardboard can also help.
It is also important to store the furniture horizontally and avoid stacking under heavy pressure. This prevents deformation and protects the painted surface from cracking. For delicate surfaces, bubble wrap or foam pads are additionally recommended.
I am happy to add a brief step-by-step guide for the safe transport of Brimnes furniture:
1. Disassemble the furniture: Carefully store screws in labeled bags.
2. Cushion surfaces: Use blankets or bubble wrap, paying special attention to protecting edges.
3. Packaging: Use your own boxes or Ikea boxes where possible.
4. Loading: Transport parts lying flat, with heavier items placed at the bottom.
5. Securing: Use ratchet straps or strong belts to prevent shifting.
6. Transport vehicle: A flat surface without loose items is ideal.
Common mistakes include insufficient cushioning of surfaces and inadequate securing inside the vehicle, both of which often lead to damage.
LOJOPAR schrieb:
Typical mistakes include lack of padding on the surfaces and insufficient securing inside the vehicle, both of which often cause damage.I completely agree. Another important point: Brimnes furniture has a coated surface that can be easily damaged by pressure marks. Therefore, it is advisable to add foam strips at points that come into contact with the load or vehicle during transport. This greatly reduces localized pressure.
Additionally, moisture should be avoided during transport, as dampness can damage the surface and especially the edges.
joroti schrieb:
Do not stack on top of each other.Exactly, this is important. Especially Brimnes doors or drawer fronts can scratch easily if they are subjected to too much pressure. Additionally:
- Make sure that no sharp-edged objects come into direct contact with the surface during transport.
- For transporting particularly large cabinet parts, I recommend laying them on the back, with the front side facing up and protected with soft padding.
- Depending on the vehicle size, it may also be worth considering keeping the furniture in the original IKEA boxes, as these are already optimized for the shape and provide protection against impacts.
In conclusion: careful handling and proper packing are the best ways to avoid damage.
