ᐅ How can Ikea Pax closets be securely fastened in multi-story houses?
Created on: 9 Apr 2020 19:37
Keonicho33
Keonicho33
9 Apr 2020 19:37
I plan to install an Ikea Pax wardrobe in my multi-story house, paying special attention to ensuring it is absolutely stable and securely fixed. The walls here are typically made of drywall with timber stud framing, and the ceiling height is just over 2.5 meters (8 feet). My goal is to prevent the wardrobe from tipping or falling, even when fully loaded or if a child shakes it.
My specific question is: What special methods or additional brackets are recommended for securely fixing an Ikea Pax wardrobe in a multi-story house with drywall and timber stud walls? Should I use specific anchors or screws, and is it worth securing the wardrobe additionally to the ceiling or floor? Are there safety tips beyond the original Ikea installation instructions, especially for use in family homes or rental properties where stability is particularly important?
I appreciate all experiences and suggestions!
flo56
9 Apr 2020 20:21
Good evening,
to securely fasten an Ikea Pax wardrobe in buildings with drywall and timber framing, the following points should be considered:
- Anchor only into the load-bearing timber studs, not directly into the drywall.
- Use wood screws of sufficient length (at least 5cm (2 inches) penetration into the wood).
- Use suitable angle brackets or metal eyelets to additionally secure the wardrobe against tipping forward or sideways.
- The wall fasteners supplied by Ikea are usually designed for solid walls, so they should be replaced with stronger fixings.
- An additional connection to the floor using sturdy furniture anchors can increase stability but is not absolutely necessary.
In short: the main task is to ensure a secure connection to the timber studs, which means locating the studs before drilling and attaching screws precisely there. If you also connect the wardrobe to the ceiling, the ceiling must be load-bearing, which can sometimes be problematic with lightweight ceilings.
The most important thing is that the wardrobe stands firmly not only against the wall but also on the floor to avoid pressure marks and prevent tipping completely.
sarGabriel
9 Apr 2020 21:03
In short: screw directly into the wooden studs, do not use anchors in the drywall.
Use angle brackets for extra stability; for homes with children, I recommend floor anchoring.
The Ikea mounting kit is not sufficient for drywall walls.
KODAN32
10 Apr 2020 08:44
I would like to briefly explain a safe method to mount Ikea Pax wardrobes on drywall with a wooden stud frame:
1. Preparation:
- Locate the wooden studs using a reliable stud finder.
- Mark the drilling points in the center of the studs, as only there is there sufficient load-bearing capacity.
2. Choice of fasteners:
- Screws with a diameter of at least 6 mm (1/4 inch) and a length of 6–8 cm (2.5–3 inches) to ensure deep enough penetration into the studs.
- Screws with chipboard tips or wood threads are ideal.
- Avoid anchors that only hold in drywall.
3. Mounting:
- Position the wardrobe against the wall; a helper can hold it in place.
- Pre-drill at the marked points to prevent splitting the wood.
- Secure the wardrobe to the studs using angle brackets or the Ikea mounting brackets.
4. Additional measures:
- For taller wardrobes (over 2 meters (6.5 feet)), connect the upper back to the ceiling if the ceiling is stable (concrete or load-bearing wooden beams).
- Alternatively, create a floor attachment, for example small brackets at the feet screwed to the floor.
Common mistakes:
- Attaching only to the drywall.
- Too short screws that do not hold deeply enough.
- Missing protection against tipping sideways.
Conclusion: Securing to the wooden studs is absolutely necessary! If you are unsure, I recommend getting help from a second person or a professional builder.
Franz
10 Apr 2020 10:17
I fully understand the need for safety, especially when children are nearby.
flo56 schrieb:
The wall fasteners included by Ikea are usually designed for solid walls, so they should be replaced with stronger fasteners.
That’s an important point, as I was also concerned when we had a wall made only of drywall at home. For example, I attached small anti-tip straps to the cabinet and securely screwed them into the wall, which gives me an additional sense of safety.
Sometimes it also helps not to fully load the cabinet or to place heavy items on the lower shelves.
Many people report that properly distributing the weight inside the cabinet makes a big difference – it makes the whole structure more stable.
lis64
10 Apr 2020 14:26
In buildings with drywall and wooden studs, always screw directly into the studs.
Replace original Ikea brackets with metal corner brackets.
Place the cabinet as close to the wall as possible to prevent tipping.
