ᐅ How can Ikea Pax mirrors be securely attached to doors?
Created on: 19 May 2015 08:47
Marcus0
Marcus0
19 May 2015 08:47
Hello everyone, I am currently planning to equip my Ikea Pax sliding doors with the matching mirrors. I’m wondering how to secure these mirrors as safely and permanently as possible, so they don’t come loose or get damaged during everyday use.
I am particularly interested in recommended mechanical fastening methods, whether it’s better to use the supplied mounting kits or if there are alternative solutions for more stable mirror attachment.
Are there also any specific considerations regarding the handling of the doors, or their thickness and material, that I should be aware of to avoid damaging the mirrors?
I look forward to your experiences and tips!
dota57
19 May 2015 10:22
Marcus0 schrieb:
I am particularly interested in which mechanical fastening methods are recommended, whether it is better to use the supplied mounting kits or if there are alternative solutions to secure the mirrors more firmly.
This is a very important question. In general, I recommend starting with the fastening materials provided by Ikea, as these are designed specifically for the construction of the PAX doors. The mirrors are usually attached directly to the door frame using clips or screw fasteners.
Warning: Some doors have a thin particleboard core, which may not be designed to support heavy loads. If the mirrors are relatively large, you can additionally reinforce them with small metal brackets or strong double-sided mounting tape.
It is important to work precisely when drilling and screwing to avoid surface bubbles. It is also advisable to test the door’s functionality before permanently attaching the mirrors to avoid the need for later adjustments.
Josan
19 May 2015 13:36
dota57 schrieb:
Mirrors are usually fitted directly into the door frame using brackets or screw fasteners.
Additionally, it should be noted that Ikea PAX mirrors are often prepared to fit into aluminum frames or slot profiles.
For secure mounting, there are two proven methods:
- Installation with the original clips and screws included in the assembly kit: These are matched to the chosen door model and ensure a secure hold.
- If you are looking for an even stronger connection, frame-mounted mirrors fixed with metal mirror clamps are suitable. The clamps are screwed to the door and securely grip the mirror.
Also, you should check that the mirror does not come into contact with the door when opening and closing, as this can cause cracks.
It is also important to clean the surface and the back of the mirror before installation to remove dust and dirt, which can negatively affect adhesion.
klo40
20 May 2015 09:02
Hello Marcus0,
I recently attached a mirror to an Ikea PAX door myself and would be happy to share my approach and experiences. My recommendation for a secure and lasting installation is as follows:
- Step 1: Preparation
First, check whether the mirror has the correct size and thickness for your doors. Ikea provides clear specifications for each door.
Remove protective films only immediately before installation.
- Step 2: Use fastening materials
Definitely use the original clips and screws supplied. For additional stability, I screwed small metal brackets inside the door.
- Step 3: Mark the exact mounting position
Mark the precise locations for the fastenings on the door. Be careful not to drill too close to the edge.
- Step 4: Installation
Pre-drill the holes carefully to avoid splintering. Use a drill bit suitable for the door material (for example, wood or metal drill bit).
Attach the clips or brackets and secure the mirror, constantly checking its alignment.
- Step 5: Inspection
After about 1-2 days, check the fittings for a firm hold. It’s better to make any adjustments early on.
Common mistakes include over-tightening the screws, which can damage the mirror, or inaccurate positioning that causes stress.
If you like, I can also provide a detailed list of the necessary tools and materials.
