ᐅ How do you repair dented pockets in PAX drawers?
Created on: 27 Jul 2019 09:12
SIMAN
I recently noticed that some of my IKEA PAX drawers have small but visible dents and creases. These not only affect the appearance but also sometimes impact the smooth operation of the drawers. Since I like to maintain my furniture myself and want to avoid unnecessary expenses, I’m wondering: what is the best way to repair dents in PAX drawers?
I’m especially interested in which tools and techniques work well for pulling out or smoothing the dented areas without damaging the surface or having to completely disassemble the drawer. I’m also curious about experiences with repair kits or tricks that have proven useful in everyday situations.
Thanks in advance for your advice!
parbau
27 Jul 2019 14:37
Hi SIMAN, great topic! I used to have dented Pax drawers as well – it was really frustrating because it completely ruined the look. One small trick I often recommend: after removing the drawer, try pulling the dent out from the inside using a suction cup, or gently work on the deformation with a clamp and a wooden board, similar to fixing a car dent. It requires patience but is very gentle on the drawer front.
It sounds strange, but it often works better than using force. And yes, a hairdryer can work wonders, but be careful. Being a bit creative is often quite fun—I hope you find the right way!
Lisele
28 Jul 2019 08:51
I just wanted to mention that this kind of repair can also be a bit challenging emotionally. You invest time and worry about possibly causing more damage.
Siman, if you decide to try heating it with a hair dryer, make sure to take breaks and check how the surface is reacting in between. It can be frustrating if the dent doesn’t disappear right away, but usually, taking it slow and being gentle works.
I’m keeping my fingers crossed and would be happy if you keep us updated on your progress!
TRA33
28 Jul 2019 09:14
Pull out the drawer and carefully push the dent out from the inside using a piece of wood. Use a hairdryer on medium heat to warm the material, making it more flexible. Do not apply force.
V
volker0
28 Jul 2019 11:36
SIMAN schrieb:
The note about the base also sounds interesting. What exactly should I use here? Some kind of sturdy wooden board or something softer?
A sturdy board is better. Softer material cannot distribute the force evenly, which makes it harder to push out.
Luciandi
29 Jul 2019 10:05
I understand well how it feels when a beautiful cabinet front suddenly gets damaged and you don’t want to seek professional help.
A small tip from me: work in stages. Warm it up, press it, let it cool, and check it repeatedly in between. Sometimes the whole problem can’t be solved at once but step by step.
Be patient and good luck!
