ᐅ How do you repair damaged edges on Ikea Hemnes furniture?
Created on: 31 Dec 2022 09:17
tolina
tolina
31 Dec 2022 09:17
I have a Hemnes nightstand from Ikea at home, and unfortunately there are some minor damages and scuffs on the corners and edges of the furniture.
How can damaged edges on Ikea Hemnes furniture be properly repaired to make them as inconspicuous as possible? I am especially interested in durable methods that do not further harm the wood or surface and preserve the original look well.
Are there any material recommendations (such as specific wood fillers, furniture markers, paints) or helpful techniques? I would appreciate your tips, particularly on how to proceed with painted surfaces.
Thanks in advance!
tra_nina
31 Dec 2022 09:45
Basically, the edges of Hemnes furniture are usually painted or covered with a thin wood veneer, which makes repairs more difficult if they get damaged.
- First, any loose parts or splinters should be carefully removed.
- For minor damage, I recommend using furniture touch-up markers in matching colors. They fill small chips well and blend visually.
- For slightly larger defects, wood filler can be used. After application, sanding is important to achieve a smooth surface.
- Finally, sealing with a suitable clear varnish is recommended to protect the repaired area from moisture and to match the gloss level of the existing finish.
It is important to match the color tone and gloss level well so the repair remains inconspicuous.
Naomige
31 Dec 2022 10:12
Hello tolina,
I understand your concern well. Hemnes is a very popular series, and damaged edges can be quite noticeable. Here are a few additional tips:
- Cleaning before repair: Remove dust and grease with some isopropanol to ensure good adhesion of filler or paint.
- If you want to fill holes or dents, you can use wood filler or a specialized wood repair putty. Make sure it’s sandable.
- After sanding: Use very fine sandpaper (220 grit) for a final pass.
- If your edges are veneered, another option is to carefully cut out the damaged areas and replace them with veneer patches. This is more time-consuming and requires some craftsmanship.
- For color matching: Furniture touch-up markers or even liquid waxes work well for small blemishes.
I recommend testing any repair on an inconspicuous spot first to minimize color differences.
Good luck with your repair!
te-min
1 Jan 2023 08:39
Brief and to the point:
- Clean the edges
- Apply wood filler or furniture putty
- After drying, sand finely
- Touch up with furniture marker or paint
This is usually sufficient for minor damages.
Gino38
2 Jan 2023 16:53
tra_nina schrieb:
First, loose parts or splinters should be carefully removed.
I want to emphasize this point because a clean edge is essential for a durable repair. If loose wood fibers are not removed, filler or paint will not adhere properly, which quickly leads to new damage.
Additionally: If you decide to paint, it is recommended to apply several thin layers instead of one thick layer. This helps prevent unsightly runs and achieves a better visual finish.
In the case of Hemnes, the surfaces are often sealed with a very thin layer of varnish. To avoid damaging this, sanding should be done carefully so that the veneer is not exposed.
Regarding materials: I have been using an acrylic wood filler for years that remains flexible and does not crack with slight movements. Combined with color-matched furniture touch-up pens, the result looks very good.
FLONE41
3 Jan 2023 12:06
Naomige schrieb:
I recommend testing any repair on an inconspicuous spot to minimize color differences.
That’s an important tip. I once forgot to do that, and the color shade was clearly different, which really annoyed me.
I think if the edge isn’t too badly damaged, you can work well with a new furniture touch-up marker and careful repainting. Especially since touching up is very quick and straightforward.
If the damage is more extensive, I’ve had good experience using a combination of wood filler and a clear varnish afterward, which restores a nice surface to the piece. This also gives the feeling of being able to care for the furniture properly without constantly worrying about further damage.
By the way: I know it’s frustrating when something you like gets damaged. But with the right technique and patience, you can almost always achieve a usable result that preserves the value of the furniture.
