I recently bought a Malm bed frame from IKEA and noticed that it doesn’t feel stable enough in the middle. Especially when turning or moving a lot, there’s some creaking or slight wobbling, which isn’t ideal in the long run.
My question to you is: What is the best way to reinforce the Malm bed frame without significantly changing its appearance or complicating the assembly? What materials or methods have you used to improve stability, particularly in the central area? Are there any known weak points to watch out for?
I would really appreciate tips, specific suggestions, and personal experiences, as I prefer not to simply screw in extra boards but rather find a well-thought-out and permanently sturdy solution.
Thank you in advance!
FABIAN_DEO9 Oct 2015 20:05Hi kajordan,
I’ll go into a bit more detail since stability is often the main concern with a MALM bed frame.
1. Weak points: The main issue with MALM beds is the lack of a central support beam or only a weakly constructed reinforcement in the middle section, especially with wider beds (e.g., 160 cm (63 inches) and above). The side frames are usually sturdy, but the slatted bed bases don’t always distribute the weight optimally.
2. Reinforcement approach:
- Add a central support beam: Ideally, use a solid wood beam (e.g., 4x6 cm (1.5x2.5 inches) pine or beech) mounted between the two long side frames.
- Fastening: Metal angle brackets are suitable for securing the beam on both ends. Screws should be at least 4 cm (1.5 inches) long to hold firmly.
- Cross reinforcement: To prevent bending of the central beam, it’s recommended to add a cross brace or a thick board screwed underneath the middle of the beam. This reduces creaking and adds extra stability.
3. Material choice: Use good-quality, preferably sanded wood without cracks. Metal parts like brackets can be painted to match the bed’s appearance.
4. Slatted bed base: If possible, use a slatted bed base with a central support and adjustable feet. These are often more stable and help distribute the load better.
Have you checked whether all your screws are tight? Sometimes just re-tightening the existing screws and reinforcing connections with wooden dowels can help.
What size is your bed exactly? And are you using a slatted bed base with a central support?
FABIAN_DEO
FABIAN_DEO
FABIAN_DEO schrieb:
Ideally, use a central support beam made of sturdy wood (e.g., 4x6 cm (1.5x2.5 inches) pine or beech), installed between the two long side frames.That’s brilliant! That’s exactly how I reinforced my MALM bed 🙂 Just added a thicker wooden slat and a small support leg in the center underneath – since then, no wobbling or creaking at all. I can only recommend it: don’t just think about it, just do it! 🙂
I would like to add a brief guide here on reinforcing the MALM bed frame, which might be helpful for someone reading this:
1. Preparation:
Measure the distance between the two cross beams of the bed, where the center support will be attached. The exact length is important for the new support beam.
2. Material procurement:
Use a solid wood strip made of pine or beech, approximately 40x60mm (1.6x2.4 inches). This is sturdy enough to handle higher loads.
3. Mark mounting points:
Mark the points on the side rails where the center support will be screwed in. I recommend using metal brackets, for example, 3 to 4 on each side, to ensure a secure connection.
4. Choose screws:
Use countersunk wood screws at least 40mm (1.6 inches) long to guarantee a firm hold in the wood. Pre-drilling is advisable to avoid splitting.
5. Implementation:
First attach the brackets to the center support, then align the support between the bed sides and screw it in place. Check that the support does not sag.
6. Optional:
For additional stability, you can install a third support leg under the center beam that rests on the floor. This reduces stress on the connections.
7. Testing:
After installation, perform a load test, for example, press lightly on the bed to check if any creaking noises have disappeared.
If you like, I can also provide tips on how to avoid common mistakes and keep the appearance looking good.
Best regards!
1. Preparation:
4. Choose screws:
5. Implementation:
6. Optional:
7. Testing:
Best regards!
rotofra schrieb:
If you want, I can also give you tips on how to avoid common mistakes and keep the appearance looking good.Hello rotrofra,
that sounds great, thanks for the helpful step-by-step guide! I would actually like to know more about how to avoid typical mistakes – for example, I’m worried about measuring something incorrectly or the screws damaging the material.
I’m also curious whether the center support beam can be easily removed later, in case I want to rearrange the bed.
How about the overall look? Do you know how I can keep the center support as discreet as possible? I don’t want to change the overall appearance of the MALM too much, since I really like the minimalist design.
Looking forward to your tips!
