ᐅ How would you assess the soil quality based on the photo?
Created on: 12 Aug 2018 18:28
M4rvin
Hello!
Here is a picture taken during site development. It looks like clay followed by sandstone...
How much do you think needs to be removed to reach fertile soil?
Marvin
Construction pit with earthworks and excavator at site, shell foundation visible, building materials on the right.
M4rvin12 Aug 2018 22:05
Great! A lot of work, but definitely worth it!
M4rvin16 Feb 2019 19:11
After the site development has been completed and the soil survey has been conducted, here is the evaluation.
BS1:
- 0.40 meters (1.3 feet) topsoil-fine sand-clay mixture
- 2.10 meters (6.9 feet) clay, silty, semi-solid, moist, gray
BS2:
- 0.40 meters (1.3 feet) clay, silty, heavily stony, stiff to semi-solid, moist, reddish-brown
- 2.60 meters (8.5 feet) clay, silty, no water encountered, semi-solid to solid, moist, gray
BS3:
- 0.20 meters (0.7 feet) clay, silty, heavily stony, stiff to semi-solid, moist, reddish-brown
- 2.30 meters (7.5 feet) clay, silty, semi-solid, moist, gray
Do I need to remove the soil and bring in topsoil? Or could I also till the soil in autumn and mix it, for example, with horse manure, sand, horn meal, etc.?
Nordlys
16 Feb 2019 19:17
Something should normally grow in the soil, but it is too dense and impermeable; it lacks air and crumb structure. Mixing in sand is a good idea. After measuring the pH value, apply lime if necessary. pH test strips are available from garden centers, for example from Neudorff. All instructions are on the packaging. I believe you can still grow grass there without bringing in topsoil. K.
M4rvin28 Apr 2019 17:45
Now that the building area has been fully developed, unfortunately, there is hardly any topsoil left. They have mixed all the dirt (clay with sandstone) into the building plots, compacted it, and applied about 5cm (2 inches) of topsoil on top.
To revisit the original idea of converting clay soil into good soil: this process takes a lot of time, involving digging over, mixing in sand, and so on. But I can’t live in a clay desert for years...
Should the soil be dug over every winter and grass reseeded in spring? Or is it enough to dig over the first winter and then just add some sand regularly afterward?
Nordlys
28 Apr 2019 19:56
No, only once. Once you have grass growing on it, the roots will loosen the soil, earthworms will settle in and further loosen it, so the process continues over time. You might need to fertilize the lawn a bit more at the beginning than elsewhere, but since the clay contains minerals, it also benefits the grass. We have also achieved good results on soil with very little topsoil, mostly clay and silt.
Garten mit Terrasse, Blockstufen, Topfpflanzen und blauem Haus im Hintergrund.
