ᐅ How can I visually integrate Ikea BRIMNES furniture pieces in an attractive way?
Created on: 23 Feb 2023 19:07
Sipra
Sipra
23 Feb 2023 19:07
I plan to combine several Ikea Brimnes furniture pieces in my living room, but I’m facing the challenge of connecting them in an aesthetically pleasing way. My goal is to create a harmonious overall impression without it looking either too monotonous or too chaotic. Since the furniture all follows the same series style, I’m wondering how to best add color and decorative accents so the pieces don’t just end up lined up next to each other. Do you have any experience or tips on how to arrange shelves, dressers, and bed frames from the BRIMNES series to achieve a balanced yet lively look? Perhaps also advice on how to enhance the furniture with suitable textiles or lighting? I would really appreciate your insights and practical suggestions!
TRADI
23 Feb 2023 21:26
Hello Sipra,
before I go into specific ideas, I would like to briefly explain the approach to visually connecting furniture from a series like BRIMNES. The series offers a clear design language and usually the same color palette, which provides a solid foundation. However, it comes down to details that loosen up and harmonize the overall look.
A few concrete tips:
- Don’t place all furniture pieces against one wall or only side by side; instead, play with spatial layering. This creates more dynamism.
- Use soft furnishings like cushions, throws, or rugs in coordinated colors that complement both the furniture and the wall color. This creates a unifying element.
- Decorative items in wood or metal tones can serve as accents to help link the furniture visually.
- Lighting is often underestimated: indirect light sources such as LED strips or floor lamps behind or beside the furniture highlight it purposefully and avoid harsh edges.
Sipra schrieb:
My main goal is to create a harmonious overall impression without it becoming too monotonous or too busy.
This is exactly the point you mentioned – the balance between uniformity and interesting variety.
I also recommend working with small plants or bundled books on the shelves, as this creates a cozy feel and visually connects the furniture.
I hope these tips help you with your planning!
Nabla64
24 Feb 2023 08:39
Hello Sipra,
here is a somewhat more detailed suggestion on how to visually connect the BRIMNES furniture in an appealing way. My experience with modular series shows that a structured approach works best:
1. Color coordination
- BRIMNES is usually available in white or black-brown. Choose a dominant base color and add one or two accent colors through decorations and textiles.
2. Consistent decoration
- Use the same materials for vases, picture frames, or boxes (e.g., metal, glass, or light wood) to create a cohesive look.
3. Textures and fabrics
- Combine soft fabrics (cushions, throws) with the smooth surfaces of the furniture. This helps soften the sharp edges.
4. Lighting
- A targeted lighting plan with warm white LEDs adds warmth to the overall appearance. LED strips under the shelves of the BRIMNES dressers work particularly well.
5. Room arrangement
- Place larger furniture such as the bed or sideboards first, then add smaller shelves as complements to create a natural flow.
Common mistakes are placing all furniture very close together and in a straight line against the wall, or using too much of the same decoration, which quickly becomes boring.
TRADI schrieb:
Lighting is often underestimated: indirect light sources such as LED strips or floor lamps placed behind or beside furniture highlight them selectively and avoid harsh edges.
I fully agree; good lighting changes the perception significantly.
If you like, I can also provide examples of color combinations.
lubla
25 Feb 2023 11:53
Sipra schrieb:
Maybe also how to enhance the furniture with suitable textiles or lighting?
For textiles, I recommend neutral colors or pastel shades that match well with white or dark brown. For lighting, warm white LED strips placed behind the furniture work well to create a cozy atmosphere.
