ᐅ How can I test the stability of my IKEA Platsa cabinet?
Created on: 10 Apr 2024 18:27
Bubi48
Bubi48
10 Apr 2024 18:27
Hello everyone, I recently assembled an IKEA Platsa wardrobe and want to make sure it is truly stable and secure, especially when loaded with relatively heavy items. My question is: How can I best test the stability of my IKEA Platsa wardrobe without damaging it or compromising its assembly? Are there specific points or areas I should pay particular attention to, such as the wall attachments, shelves, or connectors? I followed the instructions but would like to perform an additional check to ensure the wardrobe does not rock or wobble. What methods have you used for stability testing? Thanks in advance for your tips!
LOGEMIN
10 Apr 2024 19:43
Good evening! Your concern is completely understandable, especially with a modular system like PLATSA, which allows for many individual customizations. Here is a brief guide on how to check stability:
- First, inspect the entire assembly: Are all screws tightened properly? It’s common to forget to retighten screws, which can cause wobbling.
- Wall mounting is essential! PLATSA cabinets are designed to be fixed to the wall. So be sure to check whether the supplied anchors and screws have been installed into suitable walls and are firmly secured.
- Test lateral stability by gently pushing the cabinet from left to right. There should be no noticeable give.
- Shelves must be correctly and fully installed, as they provide additional reinforcement to the frame.
- Pay attention to the connectors (e.g., metal or plastic joining pieces between modules). Are these screwed in properly and are the locks engaged?
- For testing: load the cabinet section by section with some weight, such as books or household items, while observing it. If it wobbles or tilts, there’s likely an assembly error somewhere.
Summary: retighten all screws, check wall mounting and connectors, test with light loads on each section, and correct as needed. This will help prevent damage from excessive stress during testing.
I hope this helps!
U
uslis47
11 Apr 2024 08:05
Hello Bubi48, that is a very good and important question, especially with furniture like the IKEA PLATSA, which can sometimes be customized and expanded. I’m happy to give you more tips on what to watch out for:
LOGEMIN schrieb:
- Wall mounting is essential! PLATSA cabinets are designed to be fixed to the wall. So be sure to check whether the supplied anchors and screws have been installed into suitable walls and that they are firmly secured.
This is, in my opinion, the most important safety aspect. If you haven’t attached the cabinet to the wall yet, please do so as soon as possible. It can otherwise become dangerous, especially with taller units.
Furthermore, I recommend:
- Check if the cabinet stands level on the floor. Unevenness often causes wobbling. A small leveling wedge can help.
- Also pay attention to the proper installation of the back panels. They significantly strengthen the frame and are a load-bearing element for stability.
- If you have connected multiple modules, inspect the joining elements. They ensure a stable overall construction.
For the actual test: Do not slide the cabinet, but try applying gentle pressure from the outside to see if it moves or shifts. Always listen for creaking sounds, which indicate loose parts.
If you are unsure, you can also use a spirit level to detect any tilting.
I hope these tips help you!
KNUTGI
11 Apr 2024 12:39
Hey Bubi48, great to see you approaching this so carefully! I think checking furniture should definitely be done with a bit of fun – a little detective work never hurts.
I’d recommend not just testing it statically but also gently moving the cabinet doors and drawers. Especially with PLATSA, things can sometimes shift, and if the doors aren’t properly aligned, it can affect overall stability.
uslis47 schrieb:
- Also pay attention to the correct installation of the back panels. They significantly stiffen the carcass and are a load-bearing element for stability.
Absolutely, the back panel is basically the clamp of the cabinet – if it’s loose, you need to secure it. I’ve sometimes just lightly bumped the back panel and could immediately feel how much stability it adds.
My tip for the load test: small boxes or bags filled with water bottles work great, as the weight distributes evenly and you might quickly notice if anything gives way.
Finally, always remember to check the cabinet again every few months after assembly – furniture is a living object that can settle. Good luck with the testing!
