ᐅ How can I sustainably modify IKEA Hemnes furniture?
Created on: 15 Sep 2023 08:13
guteo
guteo
15 Sep 2023 08:13
I am currently looking into how to sustainably modify IKEA Hemnes furniture. Specifically, I want to change or upcycle the furniture in a way that extends its lifespan without using harmful materials or impractical methods. Does anyone have experience with environmentally friendly paints, sustainable surface treatments, or useful additions that can be made to Hemnes dressers, tables, or beds? Tips on tools or techniques that help minimize the ecological footprint are also very welcome. Perhaps you have good guides on how to transform the rather plain standard design into something durable and unique, which can also be easily recycled or reused.
I look forward to your ideas and recommendations!
Luchen
15 Sep 2023 09:48
I would suggest first roughening the surface with eco-friendly sandpaper and then treating it with certified natural oil stain. This way, the wood remains breathable and its durability is extended. Avoid solvent-based varnishes.
For fittings, you can choose stainless steel or brass instead of plastic.
Nabla64
15 Sep 2023 11:36
Hello guteo,
Here is a brief guide for sustainably modifying your Hemnes furniture:
- Step 1: Thoroughly clean the furniture to remove dust or manufacturing residues.
- Step 2: Gently sand off the original layers of paint or lacquer (grit 120-180) to create a natural surface.
- Step 3: Apply a non-toxic wood stain or pure linseed oil with a brush or cloth. Choose products with organic certification and free of VOCs.
- Step 4: For moisture protection, use a beeswax-based wax, which should be gently polished after drying.
- Step 5: Ergonomics or functionality can be enhanced with sustainable add-ons, such as handmade wooden knobs or recycled materials.
Common mistakes include sanding too aggressively, which can damage the underlying particleboard, or using cheap oils that contain harmful substances. A tip: always work in well-ventilated spaces and allow wet paint or coatings to dry thoroughly.
Good luck!
Peose
16 Sep 2023 07:29
Nabla64 schrieb:
Typical mistakes include sanding too aggressively, which can damage the particleboard underneath, or using cheap oils that contain harmful substances.
This is so important! You definitely don’t want to damage the beautiful upholstery fabric! Also, consider refreshing your furniture with sustainable fabric covers or handmade cushions! It not only looks great but also helps conserve resources 🙂
I covered my Hemnes wardrobe with organic cotton and feel really good about it! So go ahead, get creative and do something positive for the environment at the same time!
Have you experimented with natural resins or similar alternatives? I’d love to hear about it!
Lotizar
17 Sep 2023 13:04
To add the following:
The sustainability of IKEA Hemnes furniture can be improved through a combination of appropriate surface treatments and environmentally efficient repair methods.
- The Hemnes series is mostly made of pine wood, which is a relatively soft type of wood. Overly aggressive surface treatment can damage the veneer. Therefore, a light sanding with fine-grit sandpaper is sufficient.
- For paint or oil selection, I recommend products that have low emissions and high environmental compatibility (e.g., wax- or linseed oil-based).
- Screws, fittings, and handles made of metal are more durable and sustainable than plastic components.
- Repairs and adjustments should preferably be carried out using manual tools (e.g., hand screwdrivers, hand drills) to minimize the consumption of embodied energy.
Additionally, furniture can be modified modularly to facilitate later reuse, for example by using parts with standardized dimensions that can be easily dismantled. This also makes it easier to recycle or pass on the furniture later.
In conclusion: Sustainability also means choosing and working on the furniture thoughtfully—not only in terms of appearance but with a focus on material protection and durability.
