I have several IKEA Hemnes shelves set up at home. Unfortunately, the floor in that room is not completely level, which causes the shelves to wobble slightly and feel unstable. This worries me, especially when I place heavy books or decorations on them.
My question is: How can I effectively stabilize IKEA Hemnes shelves on uneven floors so they don’t wobble or tip over? Are there clever, perhaps easy-to-implement solutions you can recommend? I’m mainly interested in practical techniques that ensure long-term stability.
I look forward to your suggestions and tips!
Sydney60 schrieb:
How can I effectively stabilize IKEA Hemnes shelves on uneven floors so they don’t wobble or even tip over?Hey, great question! I know this problem all too well – uneven floors can be really frustrating when you care about safety and appearance.
What has always worked well for me:
- Small furniture glides that you simply place under the legs. Often, there are felt glides available that not only compensate for unevenness but also protect the floor.
- Extra small wedges made of wood or plastic. You can easily adjust these by trimming or sanding them.
- If it’s really wobbly, small adjustable furniture feet can help. These are available at hardware stores and are often very practical for precisely setting the height.
And one more tip: If the shelves are against a wall, make sure to use the supplied wall mounting brackets! That adds significantly more stability to the whole unit.
I hope you find a good solution that helps your room feel more relaxed!
TARAON schrieb:
Extra small wedges made of wood or plastic. You can easily adjust them by trimming or filing them down a bit.Hello Sydney60,
I’d like to build on that and suggest a small, structured approach to systematically stabilize the IKEA Hemnes shelves:
1. First, check with a spirit level or a smartphone leveling app which points of the shelf are most wobbly or not touching the floor.
2. Then prepare small spacers or wedges. These come in various materials; I strongly recommend wood because it’s very easy to work with.
3. Place the wedges under the corresponding feet and continuously check with the spirit level whether the shelf surface is level again.
4. Even better: if you want to adjust the height of the feet, adjustable metal furniture feet with threaded rods are a great solution. You can install them under the original feet or replace the original feet entirely if you are handy.
5. Finally, always secure the shelf to the wall—Hemnes shelves have fixtures for this, which greatly increase stability and prevent accidents.
Common mistakes I often see:
- Using wedges that are too thick, causing the shelf to tilt instead of stabilizing.
- Forgetting the wall attachment, which is truly essential.
I hope this brief guide helps you achieve a stable piece of furniture step by step!
Hello Sydney60,
I would like to add that for IKEA Hemnes shelves, using both floor and wall fastenings is essential, especially on uneven floors. In addition to the wedges or adjustable feet you already mentioned, you can also consider the following points:
- Use non-slip rubber pads under the feet. These not only prevent slipping but also help to compensate for slight unevenness.
- If you plan to load the shelves for an extended period, it is important to position the wedges or feet slightly beneath the bearing edge. This ensures the furniture stands firmly without putting pressure on the underside of the shelves above.
- Check the stability before attaching to the wall. Sometimes the height differences on uneven floors are so significant that wall fastenings alone do not fully prevent tipping.
If possible, improving the floor might also be worthwhile—either with a thin leveling mat or a sturdy carpet that cushions irregularities.
Good luck with your project!
Hi Sydney60,
for the Hemnes shelves, I usually use small wooden shims that I cut to size. This typically provides immediate stability. Alternatively, adjustable furniture feet that you attach under the shelf legs can help.
Don’t forget wall mounting, which is very important for higher loads.
This way, you get quick and effective stability.
