ᐅ How can I stabilize IKEA HEMNES furniture on an uneven or unstable floor?
Created on: 21 Jun 2024 08:34
Sanfi45
I have several IKEA Hemnes furniture pieces in an older house. Unfortunately, the floor there is not completely level and partly rests on very uneven subfloors. As a result, the furniture is sometimes a bit wobbly, especially larger sideboards and dressers.
My question is: What methods, materials, or mechanisms do you recommend to effectively stabilize and securely fix Hemnes furniture on such uneven and unstable floors in the long term? I am mainly looking for simple but durable solutions that do not stand out visually. It would also be interesting to know whether special adjustments to the feet are worthwhile or if it is better to use additional brackets, shims, or other aids.
I look forward to your tips and experiences!
Hello Sanfi45,
I can understand that dealing with Hemnes furniture and uneven floors is not easy.
I would definitely recommend that, with uneven floors, you first slightly lift the furniture in its position and carefully inspect the bottom of the feet. There are special adjustable furniture feet that can be screwed onto the existing feet; they don’t always replace the original feet but are attached underneath. This allows for continuous height adjustment.
If that’s not enough, use precisely cut wooden wedges, preferably made of beech or another hard wood. Don’t sand them too thin and make sure they fit well to avoid pressure marks on the furniture. For securing to the wall, I would suggest screwing a long slotted metal bracket to the furniture and then attaching it to the wall. This way, you can flexibly adjust the position, even if the wall is not perfectly straight.
If you want, I can also recommend more specialized materials.
Sanfi45 schrieb:
The unevenness is spread across the room – partly wooden floorboards, partly tiles, which are no longer completely level.This is a crucial observation. Different floor coverings and significantly varying levels make the situation especially challenging.
One tip that worked well for me: use rubber pads under each furniture leg, which allow some compensation while also protecting the flooring. Additionally, you can cut individual wedges from firm cork or rubber that adapt well to the floor’s surface and are less likely to slip.
Combining different materials – hard wooden wedges in heavily loaded areas, elastic rubber cushions for cushioning – is often the best solution for long-term stability.
Sanfi45, to further address your concern about stabilizing HEMNES furniture on uneven floors, I would like to share some additional tips for a precise approach:
1. Accurate measurement: I recommend using a digital level or laser level to determine exactly where the height differences are and how they vary across the surface.
2. Adding adjustable feet: Since the original feet on HEMNES are not adjustable, it makes sense to either obtain adjustable furniture feet made of metal tubes with threads or suitable adapters that can be mounted between the feet and the furniture. These allow for millimeter-precise adjustments.
3. Foot pads as a secondary solution: For minor unevenness, you can cut flat wooden or rubber shims, preferably from non-slip materials like rubber or cork, which should fully support the underside of the furniture to avoid point loads.
4. Wall mounting: Especially if the wall is not perfectly vertical, I recommend using tilt or swivel brackets, which allow some play during installation and prevent the furniture from being unnecessarily twisted.
5. Load distribution: Particularly with large furniture, it is important to ensure that load is evenly distributed when adjusting, to avoid stress within the furniture structure.
I’m interested to know whether the furniture is placed in a corner or freely in the room, as this also affects the stabilization.
