ᐅ How can I stabilize IKEA HEMNES furniture on an uneven or unstable floor?
Created on: 21 Jun 2024 08:34
Sanfi45
Sanfi45
21 Jun 2024 08:34
I have several IKEA Hemnes furniture pieces in an older house. Unfortunately, the floor there is not completely level and partly rests on very uneven subfloors. As a result, the furniture is sometimes a bit wobbly, especially larger sideboards and dressers.
My question is: What methods, materials, or mechanisms do you recommend to effectively stabilize and securely fix Hemnes furniture on such uneven and unstable floors in the long term? I am mainly looking for simple but durable solutions that do not stand out visually. It would also be interesting to know whether special adjustments to the feet are worthwhile or if it is better to use additional brackets, shims, or other aids.
I look forward to your tips and experiences!
warrenka57
21 Jun 2024 09:47
I’m very familiar with this issue; uneven floors can be really frustrating.
I had exactly the same problem with my HEMNES bookcase, where the floor was extremely uneven in certain spots, causing the furniture to wobble significantly. For me, it’s always important that the stabilization not only supports the furniture but also improves everyday safety to prevent anything from tipping over.
In my experience, soft furniture glides under the legs combined with small wooden wedges, cut to size, worked well. This method allows for very precise leveling of unevenness. It does require some effort, but the increased stability is definitely worth it.
nolan
21 Jun 2024 10:13
Adjust the feet. Use standard furniture wedges or silicone feet. Washers between the furniture legs and the floor also work well. Attach brackets to the wall, if possible.
Nathanaelk
21 Jun 2024 11:05
Hello Sanfi45,
Since you specifically mentioned IKEA HEMNES furniture and an uneven floor, I would like to address the problem in more detail. HEMNES furniture is usually made from solid wood or MDF panels, which generally provide a good basis for stability. However, the constructions are not designed to compensate for noticeable unevenness in the floor. The issue mainly occurs when the furniture stands securely on only three or fewer points, while the fourth leg is off the ground or the level becomes unstable due to tilting.
To solve this, you can proceed as follows:
- First, use a spirit level to check how severe the floor unevenness actually is and whether several pieces of furniture are affected.
- For direct correction, height-adjustable furniture glides made of plastic or metal are suitable; these are available as replacement parts at hardware stores or online. They are mounted instead of the original furniture legs.
- Alternatively or additionally, you can use flexible shims, which you slide at an angle under the furniture legs. It is best to use thick wood or thick rubber mats for this, as they insulate well and are non-slip.
- Wall mounts are also an important safety measure—many HEMNES models have fixtures for attaching brackets or straps. This is almost mandatory for tall chests of drawers.
A side question: How significant is the unevenness quantitatively? Is the height difference only a few millimeters, or several centimeters (inches)? This greatly affects the choice of solution methods.
Sanfi45
21 Jun 2024 13:02
Nathanaelk schrieb:
How significant is the unevenness quantitatively? Is the height difference just a few millimeters or several centimeters?
Good question. I would say that at the most critical points, the difference is between about 1.5 and 2.5 cm (0.6 and 1 inch). One edge of the furniture rests firmly on the floor, while the opposite end is slightly raised. The unevenness is spread across the room—partly in areas with wooden floorboards, partly where there are tiles that are no longer completely level.
Additionally, the wall where the furniture is placed is not perfectly vertical, so a standard wall mounting could potentially be a bit tricky.
lyndon
21 Jun 2024 14:21
For height differences of up to 2.5 cm (1 inch), I would recommend a combination of adjustable furniture feet alongside sturdy wooden wedges.
It is important that the wedges are cut precisely to avoid creating tension within the furniture, which could otherwise lead to material deformation.
Additionally, a combination of step-adjustable furniture feet and professional anti-slip pads can provide better stability on the floor. For wall fixing, flexible straps may be used to compensate for minor gaps between the wall and the furniture.
