ᐅ How can I securely install Ikea Metod wall cabinets on drywall (plasterboard) walls?
Created on: 24 Mar 2021 09:17
buwilhelm
I am planning to install wall cabinets from the Ikea Metod system on drywall in my apartment. Since these cabinets can be quite heavy and I want to ensure the safety and load-bearing capacity of the wall mounting, I have the following question: How can I securely install Ikea Metod wall cabinets on drywall?
Specifically, I am looking for recommendations on the best fastening method that is both highly load-bearing and permanently stable, as I do not have additional load-bearing walls—only standard gypsum board on wooden or metal studs.
Which anchors or special systems have been tested and are advisable? Should I drill into the studs or only into the drywall panels? How should the load be distributed?
I would appreciate detailed tips and possibly references to existing recommendations from Ikea or building professionals. Thank you in advance!
INGRID34
25 Mar 2021 10:48
Summary:
- Locate the studs
- Screw a 18mm (3/4 inch) plywood strip to the studs
- Hang the cabinets on the strip
This is how you securely fasten wall cabinets load-bearingly to drywall (gypsum board) walls.
buwilhelm
26 Mar 2021 09:34
semuneo schrieb:
You can’t simply fasten to drywall like you would with solid walls.
That is definitely the main point. For anyone who has thought drywall is strong enough for heavy wall-mounted items without special measures, I can only confirm otherwise.
To summarize my current understanding:
- Metod wall cabinets always need to be attached to the drywall’s underlying framework.
- If the studs are too far apart, install a sufficiently robust and thick mounting batten that is fastened to the studs.
- Only this batten or the studs themselves provide reliable load-bearing points.
Can anyone with practical experience share if there is an upper weight limit that can be safely supported this way? The information from Ikea tends to be quite general.
