ᐅ How can I securely mount Ikea Pax wardrobes on drywall or plasterboard walls?
Created on: 2 Feb 2018 08:17
BOGREGORIOB
BOGREGORIO2 Feb 2018 08:17Hello everyone,
I am planning to mount an Ikea Pax wardrobe on a drywall or plasterboard wall, but I have concerns about the load-bearing capacity and safety of these types of walls. My goal is to secure the wardrobe firmly so that it remains stable even when fully loaded and does not tip over or damage the wall.
My specific question: Which mounting methods would you recommend for Ikea Pax wardrobes on drywall or plasterboard walls to ensure a safe and durable installation? Which anchors or reinforcements are appropriate, and how should the wall be prepared? Does anyone have experience with the necessary preparations, such as locating the wooden or metal studs, and how best to use them?
I appreciate any detailed explanations or tips, especially advice on common mistakes to avoid.
Thanks in advance!
Thanks in advance!
Hello BOGREGORIO,
First, some basics: Drywall partitions usually consist of gypsum boards mounted on wooden or metal studs. Therefore, the load-bearing capacity is critical if you want to attach heavy furniture directly to the wall.
- It is important to locate the studs (using a stud finder or magnet). Screws must be placed there, not just into the gypsum board.
- For mounting the Ikea Pax wardrobe, make sure to use strong screws with suitable anchors. Special metal stud anchors or plastic anchors designed for drywall are possible if there is no direct attachment point on the studs.
- Ideally, screw the wardrobe directly into the studs. If the spacing between studs is too wide, you can also fix a separate wooden batten to the studs as a substructure, and then attach the wardrobe to that.
- Avoid using universal anchors that are not designed for drywall, as they may loosen over time.
- Use screws at least 6 cm (2.4 inches) long to ensure enough grip in the studs.
- Finally, it is important that the Ikea Pax wardrobe is always secured to the wall to prevent tipping hazards.
I hope this helps you already!
Hello BOGREGORIO,
your question is very well-posed because there are many pitfalls when it comes to drywall construction. I would like to add that sometimes it makes sense to use so-called heavy-duty anchors for gypsum board if you cannot reach a stud directly. These work by expanding behind the board, providing relatively strong support.
- However, I still recommend attaching the cabinet as directly as possible to the stud, as the load-bearing capacity is much better.
- Another option is to fix a substructure made of wooden battens directly to the studs and then align the cabinet to this.
- When screwing in, make sure that the screws are neither too thin nor too short, especially for heavy furniture like the Pax, which can weigh quite a bit when fully loaded.
- Also, remember to secure the cabinet against tipping by using cover strips, especially if you have small children at home. Safety should always come first.
I hope this helps, and I wish you good luck! If you like, feel free to share how it works out for you here.
kuben schrieb:
Ideally, you attach the cabinet directly to the studs. If the distance between the studs is too wide, you can also mount a separate wooden slat as a substructure to the studs and then secure the cabinet to that.This is a very good tip, as I was once worried that the cabinet wouldn’t hold properly on drywall alone. In the end, I secured my Pax wardrobe with such a wooden slat, which provided a lot of stability. There were always doubts whether that was really enough, so I think this advice is helpful for anyone with uncertainties.
You really shouldn’t cut corners here, because if the mounting holds well, you’ll have peace of mind for years and a good feeling that nothing will tip over, even if you pull hard on it.
BOGREGORIO3 Feb 2018 14:22Peone schrieb:
I would like to add that it can sometimes be useful to use so-called heavy-duty anchors for drywall when you cannot reach a direct stud.Thank you for this valuable tip. I have never worked with heavy-duty anchors before and will definitely research this further. Could you briefly explain how to choose the right heavy-duty anchor for drywall? Are there specific brands or sizes to consider, or are there standard guidelines to follow?
kuben schrieb:
Avoid universal plugs that are not suitable for drywall, as they can loosen over time.What would be practical alternatives here? Does Ikea provide recommendations for such fasteners, or is it better to go with products from a hardware store? I appreciate any advice, as I want to avoid making mistakes.
