ᐅ How can I securely fasten Billy shelves to tiled floors?
Created on: 30 May 2022 10:23
lengu
lengu
30 May 2022 10:23
I would like to securely fasten my Billy shelves to a tiled floor to prevent wobbling or tipping. Since tiles are naturally delicate and I don’t want to cause any damage, I am wondering which fastening methods are best suited for this.
Specifically, I am interested in:
- Which anchors or screws work best on tiled floors?
- Do I need special drill bits or techniques to avoid damaging the tiles?
- Are there alternative methods, such as special feet or adhesive solutions, that are stable enough?
I hope someone has experience with safely securing Billy shelves on tiled floors and can provide tips on how to do this properly and safely.
Thanks in advance for your help!
taudi
30 May 2022 11:02
Hello lengu,
I’m happy to explain how to securely fasten Billy shelves on tiled floors.
1. Drilling: Use a tile drill bit (usually carbide or diamond-tipped). Drill slowly and with light pressure to avoid cracking the tile.
2. Anchors: Special nylon or expansion anchors designed for tiles are best. For floor attachments, chemical anchors can also be used if there is enough solid material.
3. Screws: Choose screws that match the anchor size and are rust-resistant (e.g., stainless steel).
4. Fixing: For Billy shelves, I recommend attaching them directly to the wall. If you want to secure the shelf directly to the tiled floor, floor screws with suitable anchors can be used.
5. Alternative: If drilling is not an option, there are special non-slip furniture pads or adhesive strips to stabilize the shelf, but these won’t provide the same level of stability.
In summary:
- Use a tile drill bit
- Use suitable anchors
- Fasten the shelf with screws
- Alternative fixings are only suitable for light loads
Feel free to ask if you have any questions!
Marlenepa
30 May 2022 13:47
taudi schrieb:
Special nylon or expansion anchors suitable for tiles are the best choice.
This is a very important tip because some people simply use standard anchors and, in the worst case, end up cracking the tiles.
In my experience, cavity anchors (e.g., Fischer DuoPower) work very well, offering good support especially on tile floors with thinner tiles. Before drilling, make sure to check the tile thickness and use a small punch to avoid chipping the tile.
Regarding the drill bit: usually, a diamond drill bit is the best option if you don’t have a hammer drill with a tile mode yet.
Also:
If the shelf will bear a heavier load, I recommend reinforcing the mounting with wall anchors or a combination of wall and floor fixings. This way, you ensure maximum stability.
And if you are considering adhesive solutions – they can work well for small shelves but I wouldn’t recommend them for larger shelves like Billy units.
If you need help with preparation, feel free to ask!
Repar
31 May 2022 08:12
For secure mounting on tiles:
- Use a diamond drill bit designed for tiles and drill slowly
- Use suitable wall plugs (e.g., Fischer DuoPower)
- Choose rust-resistant screws
- Use adhesive pads only for very light loads
klo40
1 Jun 2022 09:56
lengu schrieb:
I want to securely fix my Billy shelves on a tiled floor to prevent wobbling or tipping.
This is a valid concern because tiled floors are durable, but drilling and excessive stress can cause damage.
Here is a brief guide:
1. Preparation:
- Check the substrate behind the tiles (is it solid concrete or a hollow structure?).
- Take your time and mark exactly where you will drill.
2. Tools:
- Use a tile drill bit (carbide or diamond tipped) as a must
- Drill with adjustable speed control
3. Drilling technique:
- Drill gradually, without hammer action, slowly
- Cool as needed with water or a damp cloth
4. Anchors and fixing:
- Use special tile anchors (e.g., hollow wall anchors or expansion plugs)
- Screws must be long enough to secure into the substrate behind the tiles
5. Stabilization:
- If possible, also fix to the wall
- Compensate uneven spots on the floor with rubber or felt pads to prevent wobbling
6. Alternative:
- If drilling is not an option, special weighted feet or furniture clamps are available, but these do not replace proper fixing.
Tip: Start with a test in an inconspicuous spot and proceed slowly. This protects the tiles and increases safety.
I hope this helps!
