Hello everyone, I am currently facing a small issue with my IKEA Malm furniture: unfortunately, my floor is not completely level, which causes the cabinets to wobble slightly and not sit flush. I would like to secure or stabilize the furniture so that it stands safely without causing damage to the floor or the furniture structure. What methods or aids do you recommend for reliably securing or leveling Malm furniture on uneven floors? Ideally, I would prefer solutions that are reversible in case I want to reposition the furniture later. Thank you in advance for your tips and experiences!
Hello Reson, basically, there are different ways to stabilize Malm furniture on uneven floors. The most common recommendation is to use furniture levelers, which are small feet made of plastic or metal with a threaded screw that can be attached under the furniture. These compensate for floor unevenness and ensure a stable stand. Alternatively, felt pads or self-adhesive pads can be used to compensate for minor height differences while also protecting the floor. If the cabinet is to be fixed to the wall, special wall brackets not only provide additional safety but often help to stabilize the furniture as well.
Hello Reson, I would like to organize my recommendation so you can proceed in a targeted way.
1. Use a spirit level to check exactly where the unevenness occurs. This will save you from a lot of trial and error.
2. For small height differences (up to about 5mm (0.2 inches)), self-adhesive leveling pads or felt gliders are suitable. They are easy to attach and can be replaced if needed.
3. For larger unevenness, I recommend adjustable furniture feet. These are screwed onto the underside of the furniture. Important: Malm furniture often has a continuous back panel, so check if mounting is possible.
4. For extra stability, especially on loose flooring, use wall fasteners, which IKEA also supplies. You should verify whether the wall type is suitable for plugs and screws.
Note: Never create excessive pressure points — do not place the furniture on just one spot to avoid damage to the material.
ladali schrieb:
Furniture levelers are the best and cleanest solution. Interesting, but I find that such levelers often only give the appearance of stability – they also wear out quickly and often look cheap.
Why not level the floor itself? That’s the fundamental solution that is often overlooked. Sooner or later, using levelers will just be patchwork. A flat floor makes life easier. And if you really need a quick-fix method, aren’t non-adhesive fiddly pads actually better than small foot plates, which offer more surface area?
In short: Sometimes it’s better to solve the root cause instead of just the symptom.
LEOIX schrieb:
Why not level the floor? That is generally true, but with old floors or rented apartments, it is often not possible—or at least not without significant effort or the landlord’s permission. For these cases, I am looking for practical solutions to stabilize furniture without having to do major alterations.
How exactly do these height-adjustable furniture feet work? Are they easy to install on a Malm dresser? And how stable are they if I only need to compensate for a few millimeters?
Height-adjustable furniture feet are simple to install. Usually, you screw them into pre-drilled holes or attach them with small screws under the furniture legs.
If you only need to compensate for a few millimeters, I recommend small feet with a slightly thicker thread to allow for precise adjustment.
With Malm, this is possible without major issues as long as you unscrew the original furniture feet and replace them with adjustable ones. Alternatively, you can also use leveling shims underneath.
