ᐅ How do I repair Malm furniture after burn marks?
Created on: 16 Jun 2021 19:07
meobrandon
meobrandon
16 Jun 2021 19:07
I discovered some unsightly burn marks on one of my IKEA Malm dressers caused by an overheated candle. The marks are noticeably darker than the surface and have slightly damaged the melamine on the front. Now I’m looking for an effective and preferably simple way to repair or at least visually reduce these burn marks. Are there any special home remedies I could try, or professional products that work well? Perhaps someone has experience with sanding and repainting Malm furniture? I would prefer not to replace the entire front if it can be avoided.
I’m looking forward to tips and some specific suggestions! Thanks in advance.
baupau
16 Jun 2021 19:45
Burn marks on melamine are difficult to remove because the surface is sealed. You can first try gently sanding with fine sandpaper followed by polishing. If that is not enough, the only option is sanding down and recoating with a suitable repair lacquer.
Takutau
16 Jun 2021 20:12
I understand your problem well; burn marks like that are frustrating. First, you should check how deeply the discoloration has penetrated the material. Melamine surfaces cannot really be sanded without causing damage because the decorative layer is very thin.
That sums it up perfectly.
My recommendation:
1. Try gently reducing the discoloration with a melamine sponge or a mild polishing agent (e.g., car polish).
2. If that doesn’t work, there are repair pens or sprays specially made for melamine and plastics that can be used to camouflage small areas.
3. Larger damage can only be repaired by replacing the panel, as sanding and repainting melamine surfaces do not work well.
I know it’s not a perfect solution, but often a slight touch-up can make the mark less noticeable. 🙂
taudi
17 Jun 2021 07:34
A brief guide on how to deal with burn marks on melamine furniture:
1. Damage Assessment: Melamine surfaces consist of a substrate panel with a decorative and protective plastic layer. Burn marks are often discolorations of this surface or slight scorching of the material.
2. Cleaning Attempt: Start by trying to remove or lighten the stains using a polish designed for plastics.
3. Mechanical Treatment: Be careful, melamine does not respond well to sanding! Excessive sanding can cause dull spots or damage.
4. Color Touch-Up: For stubborn stains, there are repair kits available (e.g., cabinet front touch-up markers for IKEA furniture) that match the colors specifically.
5. Replacement of the Front: As a last resort, ordering a new front panel is usually the cleanest solution.
Tip: Always work with fine materials and test first on an inconspicuous area. Restoring melamine is always a compromise between appearance and effort.
If you want, I can provide you with some sources for repair kits.
anken
17 Jun 2021 10:03
In addition to the previous advice:
taudi schrieb:
Melamine is not easy to sand! Excessive sanding can cause dull spots or damage.
I agree with this. Heat damage, such as scorch marks, often alters the substrate slightly, which can make the melamine brittle in that area.
My tip: If the marks are small, you can try gently using a slightly dampened fine vinyl eraser. This can remove surface dirt without damaging the material.
However, if the stain is darker and has penetrated deep into the material, the only options are to replace the affected door or have it professionally refinished by a furniture restorer.
Depending on your budget and expectations, it’s worth considering these options. Replacement doors for Malm are also available from IKEA and can be ordered relatively easily.
