ᐅ How do I repair damaged screw holes in IKEA Hemnes furniture?
Created on: 21 Jan 2024 09:17
ANDREAS7
I own several IKEA Hemnes furniture pieces, especially dressers and wardrobes, and I am now facing the problem that some screw holes in the wooden parts are damaged or stripped. As a result, screws no longer hold firmly, which affects the stability. I have already tried filling the holes with wood glue or using larger screws, but that did not really work.
My question is:
What is the best way to repair or restore damaged screw holes in IKEA Hemnes furniture so they hold firmly again? Are there proven methods or materials to properly fix the holes without damaging or altering the furniture piece?
I look forward to your tips and experiences!
My question is:
Thank you for the responses so far!
A bit about the material and situation: The furniture consists of genuine Hemnes solid wood pieces (spruce), not the cheaper version with MDF. The issue mainly concerns the corners of the dressers, where I have had to readjust screws repeatedly, and now some screws no longer hold.
I will give the toothpick and wood glue method a closer try; that sounds reasonable.
I have also considered using special wood repair putty or filler – is that effective, or is it not a permanent solution for load-bearing joints?
Additionally, can using larger screws make the problem worse, or does that make sense? I would appreciate your assessment.
ANDREAS7 schrieb:
I was also wondering if I could use special wood repair putty or filler – is that any good, or is it not a permanent solution for load-bearing joints?Wood repair putty or filler is usually not a very durable solution for structural loads like screw anchoring, as it often doesn't provide enough material to securely hold the screws.
ANDREAS7 schrieb:
Can screwing in larger screws make the problem worse, or does that make sense?Using larger screws can provide a firmer grip, but it also carries the risk of splitting the wood or creating stresses that could weaken the entire piece. It’s better to repair the hole with wood glue and wood shavings or dowels, then use a screw of the original size or just slightly larger.
If the hole is too large, the dowel method is the most stable choice. Important for Hemnes furniture: it often has pre-drilled, precisely fitting holes, so you should avoid making major modifications to them as this could reduce stability.
How comfortable are you with using drills and inserting wooden dowels?
Hi Andreas,
a quick tip if you don’t want to use wall plugs right away:
- Get some toothpicks or wooden sticks and break them to the right size.
- Dip them well in wood glue and insert them into the worn-out hole.
- Wait at least 24 hours for the glue to fully cure.
- Cut off any protruding pieces and sand the area smooth.
- Drill a small pilot hole and then carefully screw back in.
This is a simple and quick repair that works very well with solid wood; Hemnes boards are suitable for this.
Avoid using larger screws if you’re not sure, as this can cause the wood around the hole to split further.
If done correctly, this usually lasts for several years. Good luck!
ANDREAS7 schrieb:
Can I make the problem worse by using bigger screws, or does that make sense?Well, Andreas, here’s the thing: if you use screws that are too big, your dresser might surprise you one day with a “ouch” because the paint or wood could crack. 😉
It’s better to take small steps using wood glue and wooden dowels; that way, the furniture stays happy. Sometimes less is more!
Good luck with your DIY, it will hold up solidly.
