ᐅ How do I repair damaged screw holes in IKEA Hemnes furniture?
Created on: 21 Jan 2024 09:17
ANDREAS7
ANDREAS7
21 Jan 2024 09:17
I own several IKEA Hemnes furniture pieces, especially dressers and wardrobes, and I am now facing the problem that some screw holes in the wooden parts are damaged or stripped. As a result, screws no longer hold firmly, which affects the stability. I have already tried filling the holes with wood glue or using larger screws, but that did not really work.
My question is:
What is the best way to repair or restore damaged screw holes in IKEA Hemnes furniture so they hold firmly again? Are there proven methods or materials to properly fix the holes without damaging or altering the furniture piece?
I look forward to your tips and experiences!
Surela
21 Jan 2024 10:01
Hello Andreas,
first of all, an important detail upfront: IKEA Hemnes furniture is usually made from solid wood or glued wood panels with veneer, which affects your repair method. The loosening of screw holes mainly happens due to repeatedly screwing in screws or over-tightening.
My proven method is as follows:
- First, I remove all the loosened screws and clean the screw holes from any glue residues or similar.
- Then I fill the hole with wood glue (preferably a high-quality D3 adhesive) and pack small wood chips or toothpicks that fit exactly inside. This restores the material in the hole.
- After the glue filling has dried, I lightly sand the area.
- Then I drill a new, slightly smaller pilot hole into the repaired wood and screw in a slightly thicker screw that grips well in the new material.
Important:
Please try to use screws with an appropriate thread, ideally wood screws for solid wood. For larger damages, you can also use dowel sleeves (wood dowels plus glue) if you need extra stability.
Have you already checked which type of screws you are using? And what exact material is damaged (solid wood or MDF board)? This could help clarify the best solution.
tutan
21 Jan 2024 11:22
Hello Andreas!
Your topic made me smile right away – I know that problem all too well 😅. Hemnes is great, but sometimes the wood can be tricky.
I think people often rush to complicated solutions too quickly. My favorite method:
- Apply wood glue, insert small wooden sticks or toothpicks.
- Be patient (no hurry, the glue needs time to cure).
- Then use a slightly finer screwdriver or screw.
Oh, and if you’re interested, you can also try gluing in pre-made wooden dowels from the hardware store – that will help reshape the hole.
Wood definitely has its flaws here and there, but with a bit of TLC (Tender Loving Care), that thing will be solid again soon! 😊
Ankeli
21 Jan 2024 12:35
Apply wood glue and wood chips, let it dry. Then pre-drill a new hole with a smaller drill bit and insert the screw. Done.
Kinbu
21 Jan 2024 15:47
Hello Andreas,
to reliably repair damaged screw holes in Hemnes furniture, I recommend first ensuring that the piece is not affected by any structural damage. If it is really just the screw hole, the proven method is to fill it with wooden dowels or toothpick wood combined with strong wood glue.
For this:
- Prepare the wood shavings or toothpicks so they fit the hole precisely.
- Apply the glue thoroughly.
- Insert the filling material and allow it to dry for at least 24 hours.
- Lightly sand the area afterward.
- Drill a new pilot hole with a smaller diameter that is slightly shorter than the screw.
A small tip: If possible, use screws with specially hardened threads, or if in doubt, even thread inserts to ensure the repair lasts longer.
What does the furniture look like? Is it solid wood only, or are some parts veneered or made of medium-density fiberboard (MDF)? This matters for how deep and tight the screw grips.
lyndon
21 Jan 2024 17:13
Andreas,
if you want to restore stability to the screw holes, make sure to prepare the hole properly. Remove any loose fibers and debris, fill the hole with wood glue and sturdy fillers (wood chips, toothpicks), and allow the drying time.
It is important that the pre-drilled hole is not too large — just the right size so the screw holds firmly. Using a screw that is too small is not a solution either, as it may loosen.
An alternative is to use small wooden dowels with glue, fully inserted; this provides a very stable result.
Have you already disassembled the piece of furniture, or are the issues limited to individual screw connections that you want to clean or replace?
