ᐅ How do I repair damaged Malm bed legs?
Created on: 3 Feb 2022 09:27
ligotra
ligotra
3 Feb 2022 09:27
I have a problem with my IKEA Malm bed: some of the bed legs are damaged, with cracks in the wood or the surface worn off – which is not only an aesthetic issue but could also affect stability. My goal is to repair the legs so they are stable again while still looking good.
I have considered sanding the legs and filling them with wood filler, but I’m not sure which materials are suitable for the thin MDF wood or the veneered surface.
Does anyone have experience with effectively and permanently repairing Malm bed legs? Are there specific wood glues, fillers, or finishes that work particularly well?
I look forward to your tips and recommendations!
Jorgela
3 Feb 2022 11:43
Hello ligotra,
for cracks, wood glue and wood filler usually help with minor damage.
Sand the area smooth, apply the glue or filler, let it dry thoroughly, and then sand it gently again.
Finally, apply a matte varnish or clear coat to make it more durable.
GLALEO
3 Feb 2022 14:06
ligotra schrieb:
My goal is to repair the feet so they become stable again while also looking visually appealing.
It’s great that you’re taking such good care of your Malm bed! 🙂
Try using a special wood filler for MDF, which is very flexible and adapts well to the surface. After it dries, you can sand it smooth with fine-grit sandpaper for a perfect finish.
If you then apply a clear varnish or matching furniture paint, it will look almost like new!
Patience pays off – even small damages can be repaired very well. Good luck!
Julien
4 Feb 2022 08:17
Jorgela schrieb:
Sand the area smooth, apply the glue or filler, let it dry thoroughly, and then sand it again finely.
That’s a good start. I would add that before applying anything, you should make sure the surface is clean and free of grease. MDF does not tolerate excess moisture, so using a wood filler specifically designed for MDF or veneered surfaces is important.
If the damage is deeper, you might also consider small repairs with matching wooden dowels or fillers to ensure stability.
Finally, be sure to choose paint or varnish that matches the original shade; otherwise, the repair will unfortunately stand out.
If you have any further questions, just let me know 🙂
