I discovered a broken edge on one of the shelves of my Billy bookcase from IKEA. It’s the front edge, which has broken off quite unevenly – this mainly affects the thin layer of melamine coating that is peeling away, and the underlying particleboard has also slightly split.
I don’t want to replace the entire bookcase but rather carry out a repair that is both visually appealing and strong enough to remain functional.
My specific question is: what is the best way to repair a broken edge on Billy bookcases? Which materials and techniques make sense to restore the edge to a reasonably durable and attractive condition? Is sanding and repainting an option? Or should I consider a special edge banding or a wood glue repair instead?
I look forward to your experiences, tips, and perhaps even step-by-step instructions. Thank you in advance!
Hello Litau,
if the melamine coating has chipped off and the plywood underneath is split, I would first lightly sand the damaged area. Then apply wood glue into the cracks and clamp it until dry. For the appearance, you can then apply a furniture foil or edge protector. Painting is rather difficult due to the melamine surface.
Regards
Regards
Hello Litau,
I’m happy to provide you with a simple guide on how to efficiently and neatly repair the broken edge of your Billy shelf:
1. Preparation: Carefully remove any loose parts and gently sand the damaged melamine surface around the break with fine sandpaper (grit 180-220).
2. Stabilization: Apply high-quality wood glue (e.g., Ponal or similar) to the split areas. Press the edge together or use clamps if possible, and let the glue cure for at least 12 hours.
3. Visual repair: To restore the damaged melamine surface, I recommend either:
a) Applying a self-adhesive melamine edge strip in a matching white or wood finish. Make sure to measure accurately and press the strip firmly onto the edge.
b) If you want a more permanent solution and have experience with painting, you can carefully treat the repaired area with a specialized melamine paint (apply very finely!). However, this is often quite challenging.
4. Finishing: You can smooth out any unevenness lightly with very fine sandpaper.
Common mistakes to avoid:
- Using too much glue, which can squeeze out and look messy.
- Not applying enough pressure while the edge dries, which reduces stability.
- Painting directly without proper preparation often leads to poor results.
For materials, check hardware stores or IKEA directly for suitable edge strips.
If you need more details, I’m happy to help.
pauPierce23 Dec 2019 11:22Hello Litau,
before you start the repair, it would be helpful to know the exact type and extent of the damage. Is the break only superficial (melamine foil) or does it go deep into the substrate material (particleboard)? How stable is the bond at this point?
This sounds like a typical delamination damage, where the melamine foil loses adhesion and the panel underneath shows cracks.
Step 1: Clean the damaged area well, removing loose fibers, dust, or glue residues without causing further damage to the panel.
Step 2: If the gap is not too deep, try mixing wood glue with fine sanding dust (collected from the shelf itself). This thickens the glue and makes the repair area look much more uniform after curing.
Step 3: Apply this mixture into the cracks using a small spatula and gently press the edges together. This usually helps create a stronger bond than glue alone.
Step 4: After curing, sand the repaired surface smoothly with fine sandpaper. I recommend a grit of 240 to 320 to avoid damaging the surface.
Step 5: Since Billy shelves have a melamine surface, painting is problematic because conventional paint usually does not adhere well. I suggest precisely cutting and applying a matching self-adhesive edge banding or veneer foil (self-adhesive).
Alternatively, there are so-called edge banding tapes available in various furniture shops. For these, you will need an iron and some practice to avoid bubbles and wrinkles.
I would recommend not to heavily load the shelf before the glue is completely dry and the edge is restored.
One more question: Is the shelf already heavily loaded or mainly used for decorative purposes? That could help to assess the effort required for the repair.
Best regards!
Litau schrieb:
this mainly concerns the thin layer of the melamine coating that is peeling off, and the particleboard underneath has also slightly split
Best regards!
