ᐅ How do I paint BILLY bookcases?
Created on: 12 Jan 2020 08:13
kent56
kent56
12 Jan 2020 08:13
Hello everyone, I would like to paint my Billy shelves, but I have little experience with furniture makeover so far. Specifically, I’m interested in which preparation steps I should follow (e.g., sanding, priming), what types of paint work best, and if there are any special techniques to achieve an even and durable finish. I would also like to know whether I should completely disassemble the shelf or if it’s possible to paint furniture pieces without taking them apart. I would appreciate it if you could share your experiences or tips, as I want to approach this project as cleanly and long-lasting as possible. Thank you!
cecile65
12 Jan 2020 09:45
For BILLY shelves, you should first thoroughly clean the furniture and then lightly sand it to help the paint adhere better. After that, I recommend using a good primer, especially one designed for MDF or particleboard. You can then apply acrylic paint, which is durable and easy to work with. Completely disassembling the unit is not strictly necessary but depends on your painting process.
Ernesto
12 Jan 2020 11:27
Thanks for the great introductory question! When painting BILLY shelves, which usually consist of particleboard with a melamine coating, proper preparation is crucial, as already mentioned. This is where things start to separate the experts from the novices:
1. First, thoroughly clean the shelves with a degreasing cleaner. Dust, grease, and dirt prevent primer and paint from adhering properly.
2. Sanding: It is important to slightly roughen the surface here, ideally with fine sandpaper (grit 220). The melamine coating is very smooth and durable, which makes applying paint more challenging.
cecile65 schrieb:
For BILLY shelves, you should first clean the furniture thoroughly and then lightly sand it so the paint adheres better.
Regarding the primer, I recommend a bonding primer specially designed for smooth surfaces (e.g., acrylic- or epoxy-based). This ensures that the subsequent paint doesn’t peel off.
As for the paint: water-based acrylic paints are especially suitable for indoor use because they have low odor and dry quickly. There are also special furniture/metal paints that are very abrasion-resistant.
In my opinion, disassembling the shelf is advisable to treat all surfaces evenly. Painting the shelf while assembled often leads to difficulties around edges and corners and can cause unsightly drips.
How do you plan to paint it exactly? Are you using a spray gun, brush, or roller? The choice of tool also greatly affects the result.
Jonna
12 Jan 2020 13:52
I would like to add that, especially with BILLY shelves and their smooth surface, the adhesion of the paint should not be underestimated. Light sanding between coats is also recommended to eliminate unevenness and achieve a smooth finish.
Furthermore, the room should be well ventilated and maintain a consistent temperature to optimize drying. The thickness of the paint layers also affects the outcome: thin layers are best and do not unnecessarily extend drying time.
Choosing the right tools is important here: a fine foam roller works better than a coarse brush to avoid streaks.
KODAN32
13 Jan 2020 07:36
I would like to offer a practical, hands-on tutorial on how I would approach painting a BILLY bookshelf:
1. Disassembly: Completely take apart the bookshelf, remove all shelves, and keep the screws stored safely.
2. Cleaning: Clean the surface with isopropanol or a mild dish soap, then let it dry completely.
3. Sanding: Lightly scuff the melamine surfaces with 220-grit sandpaper. Avoid sanding too hard to prevent damaging the substrate.
4. Dust removal: Wipe down with a slightly damp cloth to remove dust.
5. Priming: Apply an adhesion primer suitable for laminate surfaces, ideally using a small foam roller.
6. Intermediate sanding: After drying, smooth out any minor uneven areas with 320-grit sandpaper.
7. Painting: Apply 2–3 thin coats of acrylic or acrylic-based paint. Allow proper drying in a well-ventilated area.
8. Final treatment: Optionally, seal with a matte clear coat.
Common mistakes include applying paint layers that are too thick, repainting too quickly, and insufficient surface preparation.
Ernesto schrieb:
Taking the bookshelf apart is, in my opinion, advisable in order to treat all surfaces evenly.
That’s exactly what I would recommend as well. Although it involves more work, it greatly improves the final result.
JAPLO
13 Jan 2020 09:19
To summarize a tip regarding paint selection: For BILLY shelves, I recommend clear varnishes or opaque acrylic paints that are specifically designed for furniture and do not dry too hard, as these remain somewhat flexible during use.
It is also important to allow a long curing time after painting. Even if the surface feels dry, the shelves should ideally be fully cured for at least one week before being subjected to any load.
KODAN32 schrieb:
Typical mistakes include applying layers that are too thick, repainting too quickly, and insufficient preparation.
I can only agree with that. Patience during application always pays off.
