Hello everyone, I recently bought the Metod base cabinets from IKEA and plan to install the corresponding shelving units on top to create more storage space and improve the appearance. However, I am wondering how to securely and stably attach the Metod shelving units to the base cabinets. Are there specific brackets, screws, or anchors I need to consider? Do I need to drill holes beforehand, or can I simply place the shelving units on top and fix them in place? I don’t want to take any risks because I’m worried the construction might become unstable or the cabinets could get damaged. Can someone explain the exact procedure or give tips for a safe installation? Thanks!
Hi Gogoru, your question about installing the IKEA Metod cabinet toppers is very relevant, as proper attachment is important for stability. First: The cabinet toppers are usually secured to the base cabinets using the included hardware—mostly screws and metal brackets. Detailed procedure:
- Place the base cabinets flush against the wall; the toppers will also be aligned to this.
- Position the cabinet topper on the base cabinet, making sure the edges are flush.
- Attach the brackets to the inside of the topper cabinets and screw them from the inside into the base cabinet’s side walls.
- Depending on the model, there are pre-drilled or marked holes on the sides or back for screws.
- It’s advisable to also fix the toppers to the wall, for example with brackets, to reduce the risk of tipping.
I’m wondering if you plan to install everything on an uneven floor or if the cabinets are already properly leveled? That can affect the installation.
WYATT schrieb:
Depending on the model, holes for screws are either pre-drilled or marked on the sides or back.Hey Gogoru, this is exactly the point I want to emphasize! Most Metod sets come with pretty good pre-drilled holes and mounting hardware – so it’s actually quite straightforward. The key is to grab a cordless drill and not just tighten everything by hand. With good tools, you’ll have a stable connection in no time and can then relax completely.
Also: Don’t be discouraged if the instructions look like a mini nightmare at first. Take it step by step, and once the fittings are in place, the whole thing feels really solid.
One more tip from me: If you remove the back panel of the shelf, you can align the parts better and then reattach it easily after assembly. This way, everything fits neatly and nothing wobbles. Good luck, you’ve got this! 😉
Gogoru schrieb:
Do I need to drill holes beforehand, or can I simply place and fix the attachments?To clarify: the necessary drill holes are already included in the design—you do not need to drill anything yourself unless you plan custom modifications or your floor is uneven. Make sure the angles fit snugly on the inside and that all screws are tightened securely. If you have concerns about stability, I recommend using specialized wood glue joints in addition. This will make it even more stable.
I can understand your concerns about the assembly, Gogoru. Especially with furniture that is taller and heavier, it’s natural to worry about stability. Safety is crucial, particularly if you have young children or the furniture will be used frequently.
It might help to create a detailed plan before starting the assembly, outlining how the parts fit together. If you get stuck at any point, take a short break and reconsider the next step. The IKEA method is quite well thought out, but everyone feels uncertain sometimes.
If you like, you can share which room you are installing the shelves in and what the floor surface is like. Then we might be able to offer more targeted advice. Keep your spirits up – it’s easier than you think!
