Flying-Spark20 Jul 2008 11:30Hello,
I want to install a cable on a concrete ceiling in a garage or a larger hall. Unfortunately, the nail clips I usually use don’t work because the nails don’t hold in the concrete ceiling.
Is there another method? I would appreciate any tips.
Thank you!
Thank you!
Good morning!
Yes, there is a—unfortunately somewhat more expensive—option. There are brackets made of two parts. One part is attached to the ceiling, then the cable is inserted, and a cover is placed over it. I think 15 pieces cost around 8 EUR. The set includes the brackets and special nails; these are thick, short nails that are driven into the ceiling, with a threaded head where the brackets are screwed in.
However, with concrete, even this is often not straightforward. I usually drill a 6mm (1/4 inch) hole every 50–70cm (20–28 inches), insert wall plugs, and then simply screw the clamp tight using a cordless drill. Then put the cable in, cover it, and that's it. It takes a bit of work but will hold for the next 50 years.
