ᐅ How can I improve the stability of my IKEA Platsa cabinet?
Created on: 31 May 2019 18:43
Lomu10
Lomu10
31 May 2019 18:43
Some time ago, I purchased an IKEA Platsa cabinet and am really satisfied with the storage space. However, I have noticed that the stability is not ideal. Especially when combining several modules and placing the cabinet on a delicate floor, it sometimes wobbles, which raises concerns about safety and durability.
Therefore, I am interested in learning about practical and effective ways to improve the stability of my Platsa cabinet. I am thinking of additional fastenings, reinforcements, or suitable anchor points that can be used without affecting the appearance of the cabinet or making assembly too complicated.
Are there any practical tips that someone has already tried, such as adding angle brackets, stabilizing through floor supports, or special wall-mounting methods?
I would appreciate any helpful and technically sound recommendations, as I want to use the cabinet for a long time and safety is very important to me when it comes to furniture.
Thank you in advance!
O
onan56
1 Jun 2019 07:19
Lomu10 schrieb:
What practical and effective options are there to improve the stability of my Platsa wardrobe?
I understand that this question is quite urgent for you. I recently faced the same issue when my Platsa was slightly wobbling. In my experience, apart from securing it to the wall, the choice of flooring surface plays an often underestimated role.
I placed rubber mats under the feet. This significantly reduced the wobbling by compensating for unevenness. Additionally, I reinforced some loose panels inside by using small brackets and screws. This requires some tools and time but gives a reassuring feeling knowing everything is firmly in place.
At first, I wasn’t sure how much effort was appropriate and felt a bit overwhelmed. Perhaps you have similar concerns? But it really is worth it. The time invested pays off.
Which approach would you consider trying for your setup? Maybe we can discuss the details further.
NUPIN
1 Jun 2019 21:35
Hey, great question! 😊
I really love the Platsa too and have done quite a bit myself to make it really stable!
Here are my tips:
- Always align the modules flush against the wall and secure them with the included metal brackets!
- Buy additional stronger brackets and screw them at the top and bottom where the modules connect – this adds a lot of stability.
- Use protective glides or soft floor mats underneath, especially on tiles or hardwood floors, as they can be quite slippery.
- Install reinforcement brackets inside to prevent bending.
Don’t worry too much, but if you keep at it, it will work smoothly!
Can you tell me what you have already tried? Then I can check if there’s anything you can save on or improve! 🔧👍
LUSAR
2 Jun 2019 09:02
Lomu10 schrieb:
Are there any practical tips that someone has already tried, such as retrofitting corner brackets, stabilizing with base elements, or special wall mounting methods?
To improve the stability of your IKEA Platsa cabinet, the following approach is primarily recommended:
- Wall mounting: Use the corner brackets supplied by IKEA to secure the cabinet to the wall material (e.g., concrete, drywall with appropriate anchors). This prevents tipping.
- Connecting the modules: Join individual modules with sturdy connectors such as metal brackets or screws to ensure overall stability.
- Leveling the base: Uneven floors can cause instability. Use adjustable feet or rubber pads if needed to level the cabinet.
- Internal reinforcement: Occasionally, adding additional braces or brackets inside the cabinet can help reduce frame twisting.
Make sure to use compatible and high-quality fasteners for all measures. A stable installation requires careful assembly and ideally wall mounting.
If you provide details about the wall surface, I can offer more precise recommendations.
