DOROTHEA93 Jun 2022 08:37Hello everyone, I have several IKEA Hemnes furniture pieces (cabinets and dressers) that have unfortunately become quite wobbly, even though I have checked all the screws multiple times. These are mostly older pieces made not from solid wood but rather from particleboard with a painted surface. My question is: How can I stabilize or repair Hemnes furniture when the wobbling is not just caused by loose screws? I suspect that the material or the joints have lost stability. Are there any special tips or methods that provide long-term support without damaging the appearance of the furniture? I am especially interested in effective and proven solutions regarding the back panel or possible reinforcements. Thanks in advance!
DOROTHEA9 schrieb:
My question is: How can I stabilize or repair Hemnes furniture when the wobbling is not just caused by loose screws?I know this well; my Hemnes dressers also have this issue, especially with furniture that has been used for a long time. It can be really frustrating because you often assume the screws are the cause, but the problem often runs deeper.
One tip that helped me a lot is to add additional metal corner braces on the inside, especially where the carcass corners meet. This provides strong reinforcement and is barely visible from the outside.
Sometimes it also helps to check the back panel: if it’s not securely fixed or has warped, the entire piece loses stability. I’ve sometimes reattached it with small nails or even wooden strips.
It’s important to be careful with the material—chipboard doesn’t tolerate too much moisture or overly tight screws. So it’s better to fine-tune adjustments using the right tools.
How long have you had your furniture, and how severe is the wobbling? Is it only under load or constant?
FeAndreas14 Jun 2022 14:11DOROTHEA9 schrieb:
These are usually older pieces of furniture that typically do not consist of edge-glued solid wood, but rather particleboard with a painted surface.This is an important note because particleboard with a laminate surface is usually the main issue when furniture becomes wobbly. The joints are often made using flat dowels or Minifix cam connectors, which can lose strength over time.
To repair Hemnes furniture for the long term, I recommend the following approach:
- Carefully disassemble the piece (if possible) and thoroughly inspect all connection points.
- Remove old Minifix cams or screws and replace them with new, high-quality fasteners.
- Reinforce weak points inside the furniture by adding cross braces made from wooden slats to stiffen the corners of the carcass.
- The back panel on Hemnes units is often thin and fixed with nails. If needed, you can install a plywood back panel of the same size and secure it with screws to prevent the furniture from twisting.
Be sure the screws are not too long, as this can cause the material to split. Drill small pilot holes before screwing.
How exactly does the wobbling occur: sideways, front-to-back, or in all directions? This affects where reinforcements should be placed.
If desired, I can provide a drawing showing typical reinforcement points.
FeAndreas1 schrieb:
- Install wooden cross braces at weak points inside the furniture to reinforce the carcass corners.This is often the best solution. Additionally:
- Screw the back panel securely
- Use appropriate wood glue at connection points if necessary
- Regularly tighten the screws
This has kept my Hemnes furniture stable for years.
