ᐅ How can I customize Ikea BESTA units for sloped ceilings?
Created on: 27 Mar 2020 09:13
BARIS53
I am currently planning to use IKEA Besta cabinets to make the most of the sloped ceiling in my living room. The problem is that these cabinets are normally designed for flat walls, and I want to customize them to fit the angled wall. Specifically, I am looking for advice on how to cut or modify the standard Besta modules so they fit under the sloped ceiling without compromising stability or appearance. Are there proven methods for installing the back panels at an angle or for making the best use of the space behind the cabinets? I am also wondering about suitable accessories or tools for cutting.
Does anyone have experience with the IKEA Besta system and sloped ceilings? I would appreciate any ideas and practical tips, especially detailed instructions or personal experiences.
Thanks in advance!
bupar
28 Mar 2020 09:35
For cabinets installed under a sloped ceiling, it is recommended to secure the cabinet modules to the wall using sturdy angle brackets. These can be attached discreetly on the back of the cabinet to avoid disrupting the overall appearance.
Regarding the coverings: custom trims made from MDF or wood-based panels can be crafted to fit precisely along the angled top edge. These can be fixed in place with wood glue and small screws, and then neatly painted or veneered. Ready-made coverings for this specific purpose are not available from Ikea.
The stability of the cabinet carcass is generally not affected, as long as the connection to the wall is secure.
Luciandi
28 Mar 2020 12:10
I understand well that customizing Ikea Besta units to fit under a sloped ceiling can be frustrating, especially if you want to do it neatly. What helped me was accurately measuring the roof pitch with a protractor and creating a wooden template. This allowed me to trace the slope and then mark the cutting edges on the cabinets precisely.
ritotar schrieb:
I would recommend installing a suitable molding profile along the upper bevel – basically as a transition from the top edge of the cabinet to the sloped ceiling.
I thought that was clever too – the molding ensures a clean finish, even if the cut edge isn’t perfect.
In general, I advise taking your time, as the invisible fine-tuning really makes a big difference in the final result.
barle
29 Mar 2020 07:54
One more quick addition: I often use plywood for the back panel because it’s easy to cut and still provides stability. It’s important not to remove the back panel completely but to fit it in at an angle. Most Ikea back panels are just simple hardboard, thin and used to stabilize the frame. Therefore, I wouldn’t recommend leaving them out entirely.
Fitigu
29 Mar 2020 09:18
The best method for a clean fit on sloped ceilings with Ikea BESTA units is to take precise measurements combined with professional tools:
- Use a miter saw with an adjustable angle for the top edges
- Cut the back panels at an angle and fit them precisely
- Secure the units with special wall brackets and also at the base to prevent tipping
- Custom-made panels from MDF or HPL can provide a neat visual finish
At the same time, I recommend applying edge banding to all cut edges, as this increases durability and ensures a clean appearance.
