ᐅ How do I properly install Ikea Metod drawer runners?
Created on: 26 Feb 2020 14:37
Leflo42
Leflo42
26 Feb 2020 14:37
Hello everyone, I am currently about to install my Ikea Metod kitchen drawers and have a specific question: How do I properly attach the Metod drawer slides to ensure they remain stable and operate smoothly over time?
I have the instructions, but I am unclear particularly about the precise alignment and positioning of the slide rails on the side walls of the cabinet. Which screws should I ideally use, and are there any special considerations for securing the runners to the drawer itself?
I want to avoid the drawers getting stuck later or the slides loosening quickly. Are there any tips for exact adjustment or small tricks you can recommend from experience to carry out the installation cleanly and effectively?
I appreciate any help, as it is important to me to install the mechanism correctly and avoid mistakes.
Tudogo
26 Feb 2020 15:22
Hello Leflo42,
I’m happy to help!
For the Metod drawer slides, it’s important to keep the following points in mind:
- The running rails (mounted to the drawer) should be installed exactly parallel to the bottom of the drawer. It’s best to use a spirit level or tape measure to ensure the drawer will slide smoothly and straight.
- For the slides inside the cabinet, the mounting points are usually specified in the assembly instructions, but double-check that your cabinet is built at a true 90-degree angle – this is crucial for proper function.
- The screws provided in the kit are generally sufficient, but if you want a particularly strong connection, you can use self-tapping stainless steel screws to avoid rust and expansion issues.
For adjustment:
- After installation, small misalignments can be corrected using the adjustment options on the slides. Do not fully tighten the slide screws until everything is properly aligned.
- Also, make sure that the plastic end stops on the rails are intact. They prevent scratches and help the drawer glide smoothly.
If you have any more questions, feel free to ask!
sonplo
26 Feb 2020 17:45
Hello Leflo42,
Your question is very clearly formulated – I like that. Basically, for the Ikea Metod drawer slides, precise positioning is crucial.
- The mounting rails on the cabinet are usually installed exactly 37 mm (1.5 inches) from the edge of the cabinet.
- Make sure the screws are driven in deep enough and straight, otherwise the rails can become bent or misaligned.
An important tip: The Metod slides have a small locking mechanism that keeps the drawer in the correct position. It is best to fully assemble both slide components (cabinet and drawer) first, then insert the drawer, and adjust the fine settings if necessary.
If you use third-party replacement products, the dimensions sometimes differ slightly from Ikea’s, which can cause problems.
Finally, I would recommend repeatedly pulling the drawer out and closing it during assembly to thoroughly check its function before tightening everything permanently.
glamo8
26 Feb 2020 18:12
Tudogo schrieb:
The runners (attached to the drawer) should be installed exactly parallel to the underside of the drawer.
Exactly. I always screw the slides in loosely at first, slide the drawer in, check the alignment, and then tighten them securely.
Leflo42
27 Feb 2020 09:08
sonplo schrieb:
The guide rails on the cabinet are usually installed exactly 37 mm (1.5 inches) from the cabinet edge.
Thanks for the hint! I just double-checked it carefully with a ruler, but in my case, the depth is only 34 mm (1.3 inches).
Could this be a problem? My cabinet is Ikea standard, but maybe there are measurement tolerances or production variations?
Perhaps I need to slightly adjust the guides, or can the system handle this without any issues?
Also, regarding your tip about the locking mechanism: how can I tell if it is correctly engaged? During testing, it sometimes feels a bit stiff.
lubla
27 Feb 2020 10:37
Yes, if the guides are not positioned correctly, the drawer will not slide smoothly.
In short: try to maintain the 37 mm (1.5 inches) spacing; if it’s too tight, drill new holes.
