ᐅ How do I correctly assemble Ikea Metod cabinets with soft-close drawers?
Created on: 10 Oct 2023 18:23
Hauno
Hauno
10 Oct 2023 18:23
I am planning to buy and assemble some Ikea Metod kitchen cabinets with soft-close drawers. Since I already have some experience with furniture assembly, I want to do it as correctly and efficiently as possible this time to avoid adjustments later. My main question is: How do I properly assemble Ikea Metod cabinets with soft-close drawers so that the soft-close mechanism works optimally and the drawers do not stick or close improperly?
Besides general advice, I am especially interested in tips on installing the drawer slides, their alignment and fastening, as well as the correct adjustment of the soft-close dampers. Details on assembling the fronts and inserting the drawers would also be very helpful. In your experience, are there common mistakes to watch out for?
Thank you in advance for any advice! Any detailed information that helps minimize errors will be a big step forward for me.
Matthewt48
10 Oct 2023 18:47
Hello Hauno,
First of all, great job on your request—it is very well formulated and shows that you know exactly what’s important. I have assembled several Metod cabinets with soft-close drawers and would like to provide a structured response.
When installing the drawer slides, it is crucial to work with absolute precision. Especially with Metod, it is essential to mount the slides at the correct height and align them precisely parallel to each other. Small deviations can cause the drawers to stick. Make sure not to overtighten any screws, as this can impair the mechanism.
Regarding the soft-close dampers: these usually come pre-assembled, but the adjustment is done only after hanging the drawers. Use the adjustment screws to finely tune the damping effect. It’s best to work your way from the bottom upwards, checking the function after each step.
One more tip about the drawer fronts: avoid fastening them tightly from the start. Assemble all parts of the carcass first, hang the drawers, and then adjust the fronts step by step so they align perfectly.
A common mistake is tightening all screws too early or overlooking alignment marks on the drawer slides and guide elements.
If you have any further specific questions, feel free to ask.
FLONE41
10 Oct 2023 19:09
Hi Hauno,
I can completely understand how important it is for soft-close drawers to operate smoothly. I initially had trouble too because my drawers didn’t lock in properly and always tilted to the right.
Matthewt48 schrieb:
Be careful not to overtighten screws, as this can affect the mechanism.
I can confirm that—sometimes you think the screws need to be extremely tight, but that only makes things worse. What helped me was tightening the screws just lightly and then testing.
I also had issues with alignment because I mounted the fronts too early. After loosening the screws and realigning, everything worked perfectly.
I believe patience is key. If you notice something doesn’t fit right, it’s better to loosen and adjust again rather than forcing it. Sometimes small corrections make a big difference. Good luck with your project!
FAVALERIE9
10 Oct 2023 19:31
A brief note on installing the drawer slides: Use the mounting templates provided by Ikea to precisely adjust the position of the slides. Proper alignment is crucial for smooth soft-close operation and secure drawer locking.
When hanging the drawers, make sure the slides are fully inserted before attaching the fronts. Always adjust the fronts last.
Joshbe
11 Oct 2023 07:56
For clarification: Assembling the Ikea Metod drawers with the soft-close system requires particular attention to the following points:
- First, assemble the carcass according to the instructions without attaching the drawer fronts.
- Install the runners very precisely using the supplied drilling templates. It is recommended to use a spirit level and a tape measure to check for parallelism and correct height.
- Insert the drawers only after mounting the runners. Make sure the guide rails fully engage.
- The soft-close mechanism on the runners is usually factory-set but can be individually adjusted with small screws. The goal is smooth and even closing.
- Attach and adjust the fronts only when the drawers run smoothly. The fronts have adjustment options for height, depth, and lateral positioning.
Common mistakes:
- Inaccurate installation of the runners leads to hanging or tilted drawers.
- Over-tightening screws can damage the mechanism.
- Failing to adjust the fronts after inserting the drawers.
Following these steps systematically ensures long-term functionality.
Lilau
11 Oct 2023 10:22
Hauno schrieb:
How do I correctly assemble Ikea Metod cabinets with soft-close drawers so that the soft-close mechanism works optimally and the drawers don’t stick or close improperly later?
I had the same concern and was quite nervous during assembly. For me, it’s important to take your time and avoid rushing, especially when adjusting the fronts and screwing in the drawer slides—you’ll notice quickly if you get impatient.
FLONE41 schrieb:
I think patience is key.
Yes, absolutely. What helped me was installing each drawer individually and testing it multiple times before moving on. That way, you can see if the soft-close mechanism is working smoothly or if it still needs some fine-tuning.
If the drawers did stick, I realigned the drawer slides—most of the time, that was the issue. Good luck, you can do it!
