ᐅ How can I convert IKEA BESTA into a practical living room wall unit with a workspace?
Created on: 1 Jul 2017 14:23
O
onnile
Hello everyone, I am planning to convert my IKEA Besta system into a practical wall unit with an integrated work surface and am looking for tips and experiences on the best way to do this. The goal is to maximize storage space while creating a stable, functional work area without making the overall look too cluttered or compromising the stability of the wall unit. I am also interested in which materials and fixings are recommended when partially repurposing or expanding the BESTA components. Has anyone had experience with modifications such as adding extra worktops, cutouts for cables, or integrated drawers? I look forward to your suggestions!
Sepele
2 Jul 2017 09:13
Sure! Regarding brackets: I recommend installing fasteners at least every 40-50 cm (16-20 inches) to ensure the load is evenly distributed. Usually, 4-6 brackets are sufficient – two on each side panel of the cabinet and two in the middle if the countertop is wide.
Taller and sturdier brackets (e.g., 40x40 mm (1.6x1.6 inches)) provide good stability. Small brackets alone support less load.
As for the back panels: If you partially remove them to create cable passages, you can compensate for the reduced stability by adding additional reinforcements on the sides or at the bottom, such as thin wooden strips or metal profiles.
It is important to still secure the modules to the wall; this significantly increases stability.
RABLA
2 Jul 2017 09:48
Choose a countertop made of a sturdy material whenever possible.
Angles should be screwed into solid points, on the sides and underneath.
Create cable passages by cutting out sections of the back panel.
Don’t forget wall mounting.
Pome60
2 Jul 2017 10:22
onnile schrieb:
Could you explain in more detail how to best position the brackets – is it better to use many small ones or fewer, but larger ones?
In my experience, larger brackets spaced along the length of the countertop work best. Fewer, but high-quality supports provide greater stability.
Sepele schrieb:
It is important to attach the units to the wall anyway; this significantly increases stability.
I completely agree! Especially if you have more weight on the work surface, wall mounting is essential. Don’t underestimate it! 😊
FERNANDOLO
3 Jul 2017 07:59
Remove the rear panel only as much as necessary to maintain stability.
Alternative: Drill additional cable entries in the rear panel.
Secure the countertop firmly with screws and fix it to the wall side.
