ᐅ How can I clean Malm furniture without damaging the finish?
Created on: 21 Feb 2017 08:43
tansar
tansar
21 Feb 2017 08:43
I have a few IKEA Malm furniture pieces that are coated with a clear lacquer by default. My question is: How can I clean these furniture items effectively without damaging or affecting the lacquer? I want to avoid harsh cleaning agents or incorrect methods that could leave the surface dull or stained. If there are special cleaning cloths, certain household remedies, or recommended products that are particularly gentle, I would appreciate any advice. I am also interested to know if there are any differences depending on whether the furniture has a light or dark finish.
Thanks in advance for your tips!
Merlin
21 Feb 2017 09:12
Use a damp microfiber cloth and, if necessary, mild dish soap. Do not use harsh chemicals or abrasive cleaners, as they can damage the paint.
chenlen
21 Feb 2017 10:05
When cleaning Malm furniture, it is important to avoid solvents or harsh cleaners, as these can soften the paint surface and damage the finish. A soft, slightly damp microfiber cloth is recommended. For tougher dirt, a few drops of a pH-neutral dish soap can be added to the water. After cleaning, the surface should be wiped dry with a cloth to prevent water spots.
Merlin schrieb:
Do not use aggressive chemicals or abrasive cleaners, as they will damage the paint.
I agree, as many paint damages are caused by improper cleaning.
There are generally no differences in cleaning between light and dark Malm furniture, but fingerprints are more visible on dark finishes—so it is advisable to wipe these more often with a dry cloth without water.
lopra
21 Feb 2017 12:29
Important: No solvents, ammonia, or bleach. Simply wipe the furniture with a slightly damp cloth. For grease stains, you can add a bit of dish soap to the water. Anything else may damage the finish.
Juan31
22 Feb 2017 07:53
An addition to the previous explanations: Malm furniture is coated with a synthetic resin lacquer, which is generally durable but sensitive to solvents and abrasive substances.
Avoid using alcohol, nail polish remover, or acetone as cleaning agents. Sharp scouring pads can also cause micro-scratches.
Instead, it is helpful to use a slightly damp cloth with a very mild soapy solution. After cleaning, the surface should be immediately dried with a soft, dry cloth to prevent water spots or streaks.
Regular dusting also helps prevent dust particles from scratching the surface.
chenlen schrieb:
After cleaning, the surface should be wiped with a dry cloth to avoid water spots.
This is definitely recommended.
