ᐅ How do I clean IKEA Hemnes furniture when you have children?
Created on: 7 Jul 2024 10:13
Fuonme
Fuonme
7 Jul 2024 10:13
I have several IKEA Hemnes furniture pieces at home, currently placed in a children’s room. They have gotten various stains from typical everyday kid activities, ranging from fingerprints with slightly oily residues, to rubbed-off paint marks, and sticky candy residues. My specific question is: how can I clean IKEA Hemnes furniture that has been soiled by children without causing long-term damage to the surface or the finish? Which cleaning agents or home remedies are recommended, and are there any special procedures I should follow to carefully treat the wood surfaces and remove tougher stains? I would really appreciate any practical tips or personal experiences!
geralu
7 Jul 2024 11:02
For Hemnes furniture, a damp cloth with lukewarm water usually works well. For sticky stains, add a little dishwashing detergent to the water and wipe gently. Afterwards, wipe again with a clean cloth to remove any residue. Do not use harsh cleaners, as they can damage the finish.
LOGEMIN
7 Jul 2024 13:37
To clean as gently and efficiently as possible, I recommend the following procedure:
- First, remove dust or coarse dirt with a dry, soft cloth.
- For slightly sticky stains, use lukewarm water with a drop of mild dish soap.
- Never apply the liquid directly to the wood; instead, slightly dampen the cloth.
- Afterwards, dry the surface with a dry microfiber cloth.
It is important to note that Hemnes furniture made of solid pine wood has a lacquered surface, not sealed. Therefore, moisture should generally be absorbed quickly to prevent swelling.
Household remedies such as vinegar or alcohol are not suitable because they can damage the lacquer. Abrasive cleaners are also not recommended.
For protection, after cleaning, applying a thin wax layer with a special wood care product can make the surface more resistant.
Could you please specify whether the furniture is lacquered or oiled? This often helps in choosing the best cleaning product.
Fuonme
7 Jul 2024 15:19
LOGEMIN schrieb:
Could you specify whether the furniture is painted or oiled? This often helps in choosing the best cleaning agent.
Thank you for the advice! As far as I know, the Hemnes furniture I have is sealed with a matte lacquer. It is not oiled wood, but rather a painted protective layer. Therefore, I want to treat the surface as gently as possible since the matte lacquer is prone to scratches and discoloration.
I am particularly interested in how to deal with stubborn stains without damaging the lacquer or causing glossy spots. Are there any specific cleaning products that have proven effective? And is it advisable to use polish occasionally, or is it better to avoid it altogether?
Fitigu
8 Jul 2024 09:46
Due to the matte finish on Hemnes furniture, it is recommended to use a gentle, pH-neutral cleaner for maintenance. Here are my specific tips:
- Use lukewarm water with 1-2 drops of a mild dishwashing detergent.
- Use a soft, lint-free microfiber cloth that is only slightly damp.
- For stubborn stains, you can keep the affected area damp for a few minutes, but avoid leaving moisture standing.
- Avoid aggressive or solvent-based cleaners such as alcohol, acetone, or vinegar, as these can damage the finish.
- I would not recommend polish or wax on matte furniture, as they can alter the matte effect and cause shiny spots.
Tip: Always wipe dry immediately after cleaning to prevent trapped moisture or water stains.
This is my proven standard for painted furniture, especially with a matte surface.
Nathanaelk
8 Jul 2024 14:22
I would like to add a more detailed guide, especially for dealing with common child-related stains like sticky, greasy, and colored marks on matte Hemnes furniture:
First, I recommend performing a patch test to ensure the cleaner is safe: Use a soft cloth to gently clean an inconspicuous area, then check the surface.
For typical stains:
- Fingerprints and grease spots: Use a slightly damp microfiber cloth with lukewarm water and a mild dish soap. Never scrub; always wipe gently.
- Candy or sticky residues: Treat more sensitive areas with a lightly damp cloth and some dish soap, let it sit briefly, then wipe again with clean water.
Avoid strong mechanical rubbing or abrasive cloths, as these can quickly make the matte surface shiny or cause damage.
After cleaning, always dry the surface and avoid drying in direct sunlight to minimize the risk of discoloration or swelling.
Finally, if stubborn stains remain, you can cautiously try special furniture care products designed for matte painted wood surfaces. However, I recommend testing them first in a less visible spot.
I’m curious: What types of stains do you find most often?
