I recently bought some IKEA Platsa furniture, mainly modular cabinets, which are now placed in a high-traffic area. Since the furniture is used daily, I want to make sure I maintain it properly so it stays sturdy as long as possible and its appearance doesn’t suffer. My questions are specifically:
- Which cleaning products are suitable for the surfaces and materials without causing damage?
- Are there any recommended protections against scratches with heavy use, for example on doors or shelves?
- What is the best way to care for the moving parts, like hinges or drawers, to ensure they operate smoothly and don’t wear out prematurely?
Does anyone here have effective and practical maintenance tips specifically for PLATSA under daily use? I look forward to your input and hope for helpful experiences.
Ixnefi schrieb:
Which cleaning products are suitable for the surfaces and materials without causing damage?Hey, that’s a great question! From my experience, the best option is a soft, slightly damp microfiber cloth – that won’t damage anything. You should avoid harsh chemicals; usually, mild soapy water or something similar is recommended.
To prevent scratches, it’s a good idea to use non-slip furniture pads or felt glides under the cabinets – this not only protects the floor but also reduces unnecessary friction. For the doors, self-adhesive protective films can help; they’re hardly noticeable and keep scratches away.
I personally treat the hinges now and then with a small amount of silicone spray – it keeps them smooth and helps maintain the furniture overall. So: just clean regularly, take it easy, and use these little helpers!
Ixnefi schrieb:
How can I best handle moving parts like hinges or drawers so that they operate smoothly and don’t wear out prematurely?To address this point in more detail, I’d like to take a closer look at mechanical components:
1. Hinges and drawer slides in PLATSA are usually made of metal with plastic parts. For durability, it’s recommended to clean them lightly every few months and then treat them with a suitable lubricant.
2. Recommended lubricants include special graphite powder or silicone spray, which do not stick and don’t attract dust. Oils containing acetone or WD-40 should be avoided, as they can damage plastic components.
3. Important: Avoid overloading the hinges—do not use strong, sudden movements when opening or closing. Overfilled drawers also increase strain unnecessarily and shorten the lifespan of the slides.
4. In general, screws should be checked regularly and tightened if needed, since frequent movement can cause them to loosen slightly.
Could you briefly specify in which room and with what kind of use the furniture piece is located? That will help provide more specific advice.
For cleaning and maintenance of IKEA PLATSA furniture under heavy use, please observe the following:
- Surface cleaning: Use a damp cloth with a mild soap solution. Avoid abrasive or alcohol-based cleaners to protect the melamine coating.
- Avoid scratches: Use felt pads under items placed on the surfaces and protect frequently touched areas with transparent protective film.
- Maintenance of moving parts: Silicone-based lubricants are suitable for hinges and drawer slides. Avoid petroleum-based oils, as they can damage plastics.
- Avoid overloading: Do not exceed the maximum load limits, which IKEA usually specifies, and always adhere to them.
- Regular checks: Tighten screws to maintain stability.
Following these basic guidelines significantly helps extend the lifespan of your furniture with frequent use.
stefangla12 Jan 2020 17:47Ixnefi schrieb:
Is there a recommended way to protect against scratches with heavy use, for example on doors or shelves?Preventive protection is definitely advisable. I recommend the following three-step approach:
- Preparation: Thoroughly clean the surfaces with a lint-free cloth and a mild cleaner to remove dust and dirt particles.
- Applying protection: Use transparent, self-adhesive protective films designed specifically for furniture. These protect the surface from scratches and are nearly invisible.
- Maintenance and inspection: Wipe the furniture weekly to prevent dust and abrasion. Regularly check the films for damage and replace them as needed.
This three-step method is helpful for mobile and frequently used furnishings. For drawers and hinges, I also recommend regular lubrication with silicone spray, as this significantly extends the lifespan of the mechanisms and prevents squeaking noises.
