ᐅ How do I build IKEA Metod kitchen islands with integrated workspaces and storage?
Created on: 14 Jun 2021 10:17
Karus
I am currently planning the construction of an IKEA Metod kitchen island with an integrated work area and storage, and I have some specific questions. I am especially interested in how to best combine the modules so that the work surface is functionally large enough and the storage space is optimally utilized. Are there proven combinations of base cabinets and fronts that are sturdy enough to securely support heavy countertops such as wood or stone?
Additionally, I would appreciate any tips on how to best fit the countertop to the cabinet, especially when integrating extra features like pull-out work surfaces or seating areas. How do you ensure neat wiring for electrical installations, which are often necessary for kitchen islands?
In short: How do I build IKEA Metod kitchen islands that are truly practical, have stable work surfaces, and provide sufficient storage without needing to improvise later? Thanks in advance for your detailed answers!
V
vinli
15 Jun 2021 09:33
Returning to the topic of storage and functionality, here are a few key points:
- For storage and flexible workspace, I recommend cabinets with pull-out drawers and work surfaces on rollers that can be extended.
- An island should have a minimum width of 120 cm (47 inches) to comfortably combine workspace and seating area.
- A combination of front-facing drawers and side cabinets with doors is often optimal.
faso31 schrieb:
It is also important to carefully plan before assembly whether the countertop should be split into two parts or continuous
This is an important consideration, as continuous countertops are more visually appealing but can cause unusual problems with transport and installation in small spaces.
Kabau
15 Jun 2021 10:01
Always properly support the countertop, for example by attaching wooden battens to the bottom of the cabinets. This helps to distribute weight more effectively at specific points.
For electrical work: Prepare power strips before installation to keep cables tidy and out of the way.
Storage: Drawers with dividers provide better organization.
