ᐅ How do I build an Ikea Metod kitchen island with storage myself?
Created on: 22 May 2024 09:24
jannekHello everyone,
I am currently planning to build a kitchen island myself using the Ikea Metod system and want to incorporate as much storage space as possible. Specifically, I am considering joining several base cabinets to form an island that is accessible from all sides, and additionally installing shelves or drawers to make the best use of the available space. I am particularly interested in the following points:
- How should the modules be sized effectively for a freestanding kitchen island that also remains visually appealing?
- Which base panels or plinths are suitable to keep the island stable while not making assembly more difficult?
- Are there any tips for connection techniques when combining individual Metod cabinets into a fixed kitchen island?
- How can storage be optimized through interior fittings (e.g., drawers, inserts)?
- What should I consider when planning the countertop and attaching it to the Metod cabinets?
I have seen several Ikea kitchen installations, but most are mounted against walls or arranged in straight kitchen layouts. I have not yet found reliable information for a freestanding island. Perhaps someone here has experience or can share helpful advice.
Thank you in advance!
Divide the cabinets into modules 60cm (24 inches) wide, which is standard and stable. For the connection, use connectors from Ikea accessories or regular clamps. Bases can be made of wood or metal; the Ikea bases are primarily designed for wall mounting. You can flexibly organize the interior fittings with Metod drawer inserts.
Hello Jannek,
To properly plan and build an Ikea Metod kitchen island with plenty of storage space, I recommend the following steps:
1. Planning and Dimensions:
- The standard width of Metod base cabinets is 60 cm (24 inches); you can place two or more side by side to achieve the desired width.
- The depth of the modules is usually 60 cm (24 inches), but for islands, there are also special 37 cm (15 inches) deep cabinets to allow for wider countertops.
- Make sure to allow at least 100 cm (40 inches) of free walking space around the island.
2. Connecting the Cabinets:
- Use Metod connector sets that ensure stable, connected modules.
- Additional angle brackets or metal supports can increase stability for larger islands.
3. Base and Stability:
- For freestanding islands, a sturdy base made from wooden panels or a metal frame helps support the structure.
- If you use wheels or adjustable feet, make sure they are height-adjustable and lockable.
4. Storage Design:
- There are specially designed internal drawers and pull-out organizers for Metod, which you can integrate modularly.
- Adjustable dividers and cutlery inserts also improve organization.
5. Countertop:
- A secure attachment of the countertop to the cabinets is recommended; Ikea offers mounting kits for this purpose.
- Since the island is accessible from all sides, the countertop should slightly overhang to protect the corners.
I suggest using the Ikea kitchen planner to arrange the modules in detail beforehand. Also, consider whether you want to supply the island with electricity (e.g., outlets), as proper planning of floor outlets can reduce complications.
Good luck with your project!
4. Storage Design:
5. Countertop:
Hello Jannek,
I would like to add that for a freestanding kitchen island, stability and consistent floor height are crucial. Especially when assembling multiple Metod cabinets together, it is easy for them to become uneven or wobble.
It is advisable to:
- Ensure a level base and, if necessary, install impact sound insulation or leveling mats underneath.
- Adjust all plinth feet precisely to the same height.
- Secure the connection between modules with strong metal brackets, including along the side panels.
For this, I recommend arranging them in even rows with 60cm (24 inches) width, which creates a harmonious look. Try to avoid gaps between units to minimize dust accumulation.
If you want to experiment with the countertop, you can also include an overhanging edge that allows for seating. This adds extra functionality.
Feel free to ask if you have any questions.
It is advisable to:
jannek schrieb:
How do you size the modules sensibly for a freestanding kitchen island that also remains visually appealing?
Jensson schrieb:
I recommend using the Ikea kitchen planner to arrange the modules precisely in advance.Thanks for the tip! I have already used the kitchen planner to test different combinations. One challenge is securing the countertop: I want to install a wooden countertop that is slightly thicker than the Ikea standard (about 4 cm (1.5 inches)) and extends at least 15 cm (6 inches) beyond the cabinets, mainly on the sides as a small bar overhang.
Can anyone offer advice on the best way to fasten the countertop without making the Metod cabinets unstable or causing the countertop to shift over time? Are there specific brackets available, or should I rely on glue and screws?
Additionally, I’m unsure how to neatly cover the exposed backsides (since the island is visible from all sides). Is it worth using Ikea system panels for cladding here, or is a custom solution better?
jannek schrieb:
Can anyone give me tips on how to best secure the countertop without making the Metod cabinets unstable or causing the countertop to shift over time?Regarding overall stability: The Ikea Metod cabinets are designed to support the countertop, but with an overhanging, thick wooden countertop, you should consider the following:
- Attach the countertop to the cabinets using screws from underneath, which are included in the Ikea fastening kit.
- For overhangs exceeding 10 cm (4 inches), it is recommended to add a supporting frame or wooden brackets under the countertop, which are fixed to the cabinets.
- Use wood glue as additional support, but not as the sole method of attachment.
jannek schrieb:
Also, I’m unsure how to neatly cover the backs since the island will be visible from all sides.A neat finish is best achieved by using back panels made from melamine or MDF boards, cut to size and installed. Ikea also offers matching panels for the sides. Alternatively, you can build a frame structure and cover it with laminate or paint to suit your design.
Make sure the back panels do not rest directly on the floor to prevent moisture damage.
