ᐅ What is the best way to maintain the surface of IKEA BESTA units?
Created on: 3 Oct 2021 18:23
Ploni70
I recently bought an IKEA Besta furniture piece and would like to know the best way to care for the surface to keep it looking good and undamaged for as long as possible.
The surfaces are often melamine-coated or covered with a laminate film, which may not be compatible with aggressive cleaning agents. I am particularly interested in:
- Which cleaning products are suitable, and which should I avoid?
- Are there any special care tips to prevent scratches, dull spots, or discoloration?
- What is the gentlest way to deal with stubborn stains?
I prefer not to experiment with my furniture and look forward to your well-founded recommendations and experiences. Thanks in advance!
tra_nina
5 Oct 2021 07:48
For objective clarification:
IKEA Besta surfaces mainly consist of melamine resin coatings or laminate films, which are relatively resistant to moisture and normal wear.
Cleaning recommendations based on the material properties:
- Avoid solvents such as acetone, alcohol, or stronger alcohols, as they can damage the protective layer.
- Use mild cleaning agents (pH-neutral or slightly alkaline).
- Use microfiber cloths to ensure scratch-free cleaning.
For stubborn stains, gently rubbing with a common eraser followed by wiping off is suitable.
Recommendation: Avoid waxes or polishing products typically used on wood surfaces, as these can cause uneven gloss effects on melamine coatings.
In the long term, gentle and regular cleaning contributes most to maintaining value.
kemads46
5 Oct 2021 10:19
tra_nina schrieb:
No waxes or polish products that are suitable for wooden surfaces, as these can cause uneven gloss effects on melamine coatings.
I can only confirm that. People often tend to use waxes or furniture polishes that are actually meant for solid wood furniture.
Melamine surfaces are different: they have a protective layer, but it does not respond well to chemical solvents or care products containing polishing agents. The result is unattractive streaks or spots.
My advice: If you really want to enhance the shine a bit, do so only by very gentle cleaning with a damp cloth and avoid care products that are not explicitly specified for melamine-coated furniture.
Ploni70
5 Oct 2021 14:03
kemads46 schrieb:
My tip: If you really want to enhance the shine a bit, do so only by gently cleaning with a damp cloth and avoid any care products that are not specifically intended for melamine-coated furniture.
Thank you very much for the detailed explanations and your valuable tips!
I had some concerns about polishing, but this confirms my cautious approach to commercial products.
It’s good to know that a mild cleaning method is the most effective in the long run. I will also keep the advice about direct sunlight in mind.
One last question:
What about using glass cleaner when I quickly need to remove fingerprints from the surface? Should I avoid it, or is it okay if the product is mild?
Thanks again to everyone for your detailed answers!
