ᐅ What is the best way to assemble Ikea Hemnes furniture on your own?
Created on: 28 Apr 2020 10:03
Annamu
Hello everyone, I’m currently facing the challenge of assembling Ikea Hemnes furniture completely on my own, especially a Hemnes wardrobe and a few dressers. Since these pieces are somewhat bulky and can be quite complex to put together, I’m wondering what the best approach is to assemble them efficiently, safely, and with the cleanest possible result when working alone. Are there any specific techniques, tools, or tips that have proven particularly useful? I’m also interested in how to best plan the process—whether to combine certain steps or do them one after another—to ensure the furniture is built solidly and professionally. I look forward to your advice!
Tudogo
29 Apr 2020 11:01
Hello Annamu! It’s great that you’re confident enough to assemble everything on your own! Another helpful tip might be to plan the assembly in separate sections: prepare partial assemblies so that you can easily transport and position them, which helps avoid unnecessary rearranging.
What you’ll particularly notice with Hemnes furniture are the connectors that are only used later in the instructions. These stabilize many joints, so it’s best to tighten them fully at the end.
One last note: if the piece of furniture allows it, it can be helpful to mark all parts before assembly steps, for example indicating screw positions. This way, you always know what’s done and where you currently are in the process.
Wyatt
29 Apr 2020 16:38
Hello Annamu, I would like to explain the assembly process systematically. The Hemnes series is sturdy and uses a combination of dowels and connecting screws, which are quite easy to handle, but for a single-person assembly, precision is everything.
First, the preparation: You should lay out all wooden parts before starting and check them against the instructions. Separate the screw groups, ideally in small containers, to avoid any mix-ups.
The assembly itself usually begins with the larger flat parts – side panels first, then shelves and back panels. For example, the Hemnes wardrobe has a thin cardboard back panel that is attached last; it provides the necessary stability to the frame.
If you don’t have an extra pair of hands, it’s advisable to keep the screw connections fairly loose at first, not too tight, until all parts are in place. This way you can still adjust and align the furniture. A flat work surface helps with this.
Avoid setting up the furniture alone if it’s bulky. Instead, use cushions or padding to position it upright without risking damage.
Regarding tools: In addition to Allen keys and Phillips screwdrivers, a small hammer for dowels is useful. If available, also use a cordless drill, but with low speed and careful handling.
Finally, a question: Which furniture pieces exactly do you plan to assemble on your own? Is there a specific problem area already, or would you like to discuss the overall strategy?
Josan
29 Apr 2020 18:05
Wyatt schrieb:
Finally, a question: Which specific pieces of furniture do you want to assemble on your own? Is there a current problem area, or do you want to establish the overall strategy?
That’s an important question! In my opinion, without knowing the exact scope, only general advice can be given. For smaller dressers, a simple workflow is often sufficient, but larger items like the Hemnes wardrobe require more planning.
Back to the topic: I’ve developed a habit with Hemnes dressers to first roughly assemble all side panels and base parts, and assemble the drawers separately. Installing the drawers helps with handling the main unit, which then becomes somewhat more stable.
Annamu
30 Apr 2020 08:47
Wyatt schrieb:
Finally, a question: Which specific pieces of furniture do you plan to assemble by yourself? Is there a current issue you’re facing, or do you want to discuss the overall approach?
Thank you for asking for clarification! Specifically, it’s about the Hemnes wardrobe (three doors, no drawers) and a Hemnes chest of drawers with five drawers. The main challenge with the wardrobe, I think, is mostly its size and handling the heavy parts, but I’m not sure what the best way is to manage that alone. The chest of drawers seems more manageable, but I want to avoid mistakes in the assembly sequence. I have read the instructions but haven’t started the actual assembly yet. I would appreciate any advice you can offer, especially on handling large, bulky parts and critical assembly steps.
