ᐅ How do I properly install IKEA Metod toe kicks so they fit precisely?
Created on: 25 Nov 2021 18:37
magdason
magdason
25 Nov 2021 18:37
I am about to install my IKEA Metod kitchen plinths and want to attach them as precisely as possible so that they fit neatly and without gaps. My question is: What is the best way to fix the Metod plinths so that they align with millimeter accuracy, run perfectly straight, and allow for easy adjustments later on?
I am especially interested in how to handle uneven floors and how to correctly align the plinths. Are there any special installation tips or tools that make precise fitting easier?
Looking forward to your experiences and suggestions!
sobau
25 Nov 2021 19:02
The Metod plinths are attached to the base cabinets using the designated clips.
- First, insert the clips into the plinth.
- Screw the clips onto the base cabinet.
- Snap the plinth into place and align it.
Adjustable feet under the cabinets compensate for uneven floors. This should ensure the plinth sits straight automatically.
Palenar
26 Nov 2021 09:11
For precise installation of the IKEA Metod kickboards, I recommend the following process:
1. First, carefully inspect the floor situation. Use a spirit level and a long straightedge to check if the floor is level and to identify any height differences.
2. Adjusting the base cabinet feet is crucial to ensure the kitchen units are aligned parallel to the floor. It is advisable to set the feet so that there are no significant gaps between the floor and the cabinet feet.
3. The kickboard clips should be mounted exactly at the designated fastening points. I suggest placing the kickboard temporarily before screwing to mark the clip positions accurately.
4. To align the kickboard precisely, you can make slight adjustments before snapping the clips into place. Some users use small spacers or wedges if the floor is slightly uneven.
5. If necessary, smoothing the corners and joints of the kickboards with fine sandpaper or using a special kickboard corner connector can help achieve a seamless appearance.
Tip: A narrow spirit level and sturdy squares are very helpful for achieving straight installation. Have you noticed any specific floor unevenness?
magdason
26 Nov 2021 12:44
Palenar schrieb:
Did you notice any specific floor unevenness?
Yes, exactly. I have a slightly uneven screed floor, with deviations of about 4-5 millimeters (0.16-0.20 inches) in some areas. I suspect that the baseboards won’t sit flush if I simply attach the clips.
In this case, is it better to adjust the cabinet legs so that the cabinets are completely level, or should I try to compensate for the gaps under the baseboards separately using small shims or filler materials on the floor? Is there a preferred method to achieve visually seamless edges without gaps later on?
LANICOLE
26 Nov 2021 16:05
You can address the uneven floor situation in your kitchen as follows to install the baseboards precisely:
- First, always align the base cabinets exactly using a spirit level. The adjustable feet usually allow for adjustments of several centimeters (inches).
- When the base cabinets are level, the baseboard will naturally fit better.
- If a small gap appears at the floor, I recommend using leveling wedges or thin insulation strips (e.g., cork) that can be clamped under the baseboard before the clips snap in.
- Important: Wedges or filler materials must not compromise stability but should only conceal minor unevenness.
- Trimming the ends of the baseboards is often necessary, especially if the floor is not completely even. A fine saw or fine sandpaper can help here.
Summary: First, adjust the cabinet feet, then install the baseboards, and use wedges for small unevenness. This way, you will achieve a smooth and professional result.
rekijan
26 Nov 2021 17:28
Hey, I’m not a professional, but I installed my Metod baseboards like this: first, I made sure the cabinets were perfectly aligned, then I attached the clips. When snapping the baseboards into place, you can still slightly adjust them, like a little fine-tuning. 😊
If the floor is uneven, I just used small wooden wedges – it really helps and no one can see them behind the baseboard.
Fun fact: I recently installed a clip the wrong way around by mistake, which caused some issues. So, make sure the clips are oriented correctly; otherwise, the baseboards won’t fit perfectly.
