ᐅ How do I mount Billy shelves on insulated walls?
Created on: 6 Feb 2020 14:03
Sibau
Sibau
6 Feb 2020 14:03
Hello everyone, I am planning to install several IKEA Billy bookshelves in my apartment, but the walls are covered with insulation material, and I am unsure how to mount the shelves securely and load-bearing. The insulated walls are relatively thin and consist of a drywall panel on a structured timber stud frame with insulation in between. Therefore, I cannot simply drill directly into the wall without fearing stability issues. Does anyone have experience with properly and safely mounting Billy shelves on such insulated walls? I would like to know which fasteners and techniques are suitable to ensure the shelves are stable and that no holes are made in the insulation panels that could damage or tear out the insulation. Thanks in advance for any helpful advice!
Israel62
6 Feb 2020 14:27
The best method is to locate the load-bearing wooden studs behind the drywall using a stud finder. You can then screw the shelves directly into these studs. If you cannot find a stud, special cavity anchors are the alternative.
Svenja7
6 Feb 2020 15:09
Israel62 schrieb:
The best way is to locate the load-bearing wooden studs behind the drywall using a stud finder.
This is a very important point. Especially with insulated walls, it is essential that the loads are transferred to structural elements like wooden studs or masonry. Without a secure anchoring, the screw can easily pull out and damage the insulation.
Once you have found the studs, make sure to use suitable screws that penetrate deeply enough into the wood – ideally wood screws at least 5cm (2 inches) long.
Israel62 schrieb:
If you don’t find a stud, special cavity anchors are the alternative.
Here, I would recommend cavity anchors such as metal toggle bolts or toggle anchors, which are designed for these types of walls, but they are not as load-bearing as anchoring into a stud. For heavy shelving units, especially when fully loaded, I would try to position the shelf fixing on studs.
BAUEVA
6 Feb 2020 16:42
I think it’s important to critically examine which loads actually act on the mounting at this point. A Billy shelf can hold several kilograms (pounds) of weight on the wall, especially when fully loaded with books.
Svenja7 schrieb:
to attach the shelf to studs
That’s correct, but often these wooden studs are only 4–6 cm (1.5–2.5 inches) wide, and depending on the width of the shelf frame, that can be quite tight.
Does anyone here have experience distributing loads via a special support structure across multiple studs or using additional profiles? I consider a simple cavity wall anchor set almost unsuitable when it comes to long-term stability, especially in rental units where preventing damage to insulation is important.
I would appreciate it if someone could recommend specific products or system solutions.
Roninkla
7 Feb 2020 09:11
On insulation walls with low load capacity, the best way to install Billy shelves is by attaching them directly to the supporting wooden stud framework.
If the studs are not conveniently placed, I recommend adding a mounting strip made of sturdy wood (e.g., a 2x4 cm (1x1.5 inch) batten) that you screw across the studs. The shelf can then be securely fixed to this strip.
This method prevents localized stress on the insulation and distributes the load across the strip and multiple studs.
Conventional anchors are not suitable for fixing directly into the insulation.
If no other option is available, use only tested metal toggle anchors with appropriate load ratings, but the solution with a mounting strip is more stable.
LAGUDO
7 Feb 2020 10:02
I have always attached Billy shelves in similar situations to the uprights using a crossbar. This holds very well and distributes the load more effectively. You can also reinforce the bars further by connecting them with angle brackets.
