ᐅ How do I attach additional handles to Malm drawers?
Created on: 21 Jun 2016 09:07
Erica5
Erica5
21 Jun 2016 09:07
Hello everyone, I am planning to add extra handles to my IKEA Malm dressers to make the drawers easier to open and to give the furniture a more personalized look. I am especially interested in which fastening methods are best suited without compromising the stability of the drawers. It would also be important to know how to best determine the position of the new handles so that they look balanced and do not damage the surface. Does anyone have experience mounting additional handles on Malm drawers and can offer advice on drill bit diameters, screw lengths, or adhesive methods? Tips on tools or alternative solutions are also welcome.
Jan31
21 Jun 2016 10:15
For additional handles on Malm drawers, I recommend drilling holes at the desired locations and using suitable wooden dowels with screws. Pay attention to the thickness of the drawer front and the length of the screws to avoid puncturing through. To determine the exact position, you can use a template.
PULAU
21 Jun 2016 13:28
Your question is well formulated and takes into account important aspects such as stability and appearance. To attach additional handles to Malm drawers, drilling is the most reliable method, as adhesive solutions tend to fail relatively quickly with use. Make sure to carefully measure the drawer front and pre-drill the holes with a fine drill bit to avoid cracks in the wood. The screws should be chosen so that they do not exceed the thickness of the front panel. Additionally, I recommend looking for suitable drilling templates to help ensure symmetry and even spacing of the handles.
Erica5
22 Jun 2016 08:22
PULAU schrieb:
Adhesive methods can fail relatively quickly during use.
That makes sense to me, thank you. How exactly does the drilling template work? Are there standard dimensions for Malm drawers that can be used, or should the handle spacing be adjusted individually? I ask because I have different widths and want to plan the positions precisely. Also, are there any tips to protect the surface from drill shavings or damage while drilling?
Renla47
22 Jun 2016 11:41
Hello Erica5, I’m happy to answer your questions. A drilling template is a simple tool, often made of plastic or wood, with precisely shaped holes that set the correct spacing for the screw holes. Malm drawers come in standard widths, but of course, these vary depending on the model. It’s best to measure the width of your drawer front and choose a template that matches the width and handle size you want to install. Some handle manufacturers offer templates designed specifically for their handles. Alternatively, you can make your own template by marking the desired handle positions on paper or thin wood and then drilling the holes.
To protect the surface while drilling, be sure to stick a piece of painter’s tape over the drilling spot. This prevents splintering as the drill passes through the wood. It’s also advisable to start drilling slowly with a sharp drill bit and avoid applying too much pressure. This will help prevent damage to the surface. At the end, you can lightly sand the drilled holes to smooth out any rough edges.
If you like, you can also secure the screws with a little wood glue, which will increase stability.
