ᐅ How do I attach a mirror to Ikea Pax doors?
Created on: 22 Nov 2021 19:37
friedhelmj
friedhelmj
22 Nov 2021 19:37
Hello everyone, I would like to attach a large mirror to the doors of my Ikea Pax wardrobe. The doors are usually made of a relatively thin wood or particleboard with a painted surface. My question is: which mounting methods are secure and at the same time gentle on the doors to maintain their stability, avoid visible damage, and ensure the mirror holds well over time? It would also be helpful to know if special adhesives, screws, or mounting systems are recommended, ideally with tips on surface preparation and how to prevent the doors from warping due to the additional weight.
BLAKEO
22 Nov 2021 20:11
friedhelmj schrieb:
Which mounting methods are safe and at the same time gentle for the doors, so that stability is maintained, no visible damage occurs, and the mirror remains securely fixed in the long term?
That is quite a complex question. First, you would need to know how heavy your mirror is and how thick the Pax doors are. A mirror that is too heavy on thin doors could lead to warping or damage over time.
In general, I often recommend adhesive solutions for mirrors, especially mirror adhesive or double-sided strong mounting tapes like 3M VHB, because they do not create screw holes. However, with Ikea Pax doors there is the challenge that the surface is very smooth and coated, which makes adhesion difficult.
On the other hand, screws probably only work on the door frames and not on the actual door panels, depending on their construction. Another important point is that the installation should remain reversible—in case you want to repaint or modify the doors later.
How heavy exactly is your mirror? And have you already checked how thick the doors are?
O
olivernu
23 Nov 2021 09:02
BLAKEO schrieb:
In general, I often recommend adhesive systems for mirrors, especially mirror adhesive or double-sided strong mounting tapes like 3M VHB, because they don’t cause screw holes.
That is indeed a good approach, but it depends on the size and weight of the mirror. For large, heavy mirrors, I recommend a combined method: applying mirror adhesive in small dots to optimize the bonding area, supplemented with small screws or special mirror fasteners anchored into the door frame.
It is important to thoroughly clean and degrease the doors beforehand; otherwise, the adhesive will not stick properly. A light sanding of the bonding area can further improve adhesion, as long as you proceed carefully to avoid damaging the surface.
To prevent warping, avoid mounting mirrors that are too large or heavy on the doors, and reinforce the back panels if necessary. If you like, I can also give you tips on selecting suitable screws and anchors.
friedhelmj
23 Nov 2021 17:29
BLAKEO schrieb:
How heavy exactly is your mirror? And have you checked how thick the doors are?
Thanks for asking! My mirror is about 140 x 40 cm (55 x 16 inches) and weighs roughly 6 to 8 kg (13 to 18 lbs). The Pax doors are 1.6 cm (0.63 inches) thick, as specified by the manufacturer. They have a core made of particleboard with a white melamine surface.
olivernu schrieb:
For large, heavy mirrors I recommend a combined method: mirror adhesive applied in small dots to optimize the bonding area, supplemented by small screws or special mirror fasteners that are anchored into the door frame.
That sounds good. I’m concerned that screws might loosen easily with vibrations caused by opening and closing the doors. Is there a type of thread locker or other methods to prevent this? And how would you reinforce the frame if needed? I’d rather avoid completely changing the door construction.
BLAKEO
24 Nov 2021 12:44
friedhelmj schrieb:
I’m concerned that screws might loosen easily due to the vibrations caused by opening and closing the doors.
This concern is valid. Screws can loosen, especially when they are anchored only in particleboard. One solution is to use thread-locking adhesives (e.g., Loctite) to prevent unintended loosening from vibrations.
To reinforce the attachment to the door frames, it is advisable to install small wooden battens (e.g., single-sided solid wood construction strips) on the inside of the doors, allowing the screws to anchor into a more stable material. These battens can be fixed with quality screws, and the panel can then be screwed onto them.
If you prefer no visible screws on the outside, you can attach flat angle brackets on the inside to additionally secure the panel. Additionally, adhesive reduces stress on the screws and distributes the load more evenly.
Important: The door should be handled carefully, avoiding any strong impacts or sudden movements.
