ᐅ How do I install IKEA Metod kitchen cabinets with built-in appliances?
Created on: 17 Nov 2021 08:43
gabau31Hello everyone,
I am currently planning the installation of my Ikea Metod kitchen with several built-in appliances, including a stove, a dishwasher, and a refrigerator. I have a question about how to properly assemble these kitchen units along with the built-in appliances. I am particularly interested in tips on handling the cabinets, securing the appliances, and important steps to avoid missing during installation. Are there any special tools or procedures you would recommend? I already have some experience with Ikea furniture, but I am unsure about the exact process for connecting and installing appliances. I would appreciate it if you could share your experiences!
Hello gabau31,
your question about installing the Metod kitchen cabinets with appliances is very well posed. Generally, I would recommend proceeding in the following order:
- First, assemble the cabinet carcasses, paying close attention to precise alignment and squareness.
- Before the final anchoring step, test-fit the appliances into the openings to check for proper fit.
- Special mounting brackets are provided for installing the appliances; these ensure a secure fit and safety during use.
- Connect the appliances (electricity, water, drainage) before the final tightening of screws.
A good tip is to check each installation step carefully and avoid fastening too quickly so that adjustments can still be made. Ikea provides comprehensive assembly instructions, which I find very helpful when combined with the above points.
Hi gabau31,
I can understand that installing the Metod kitchen units with appliances can initially seem a bit intimidating. I felt the same way, especially when integrating the oven and dishwasher. The important thing is to take your time and proceed step by step to avoid stress.
If you encounter any problems with the water connection, don’t get discouraged – sometimes flexible connectors are helpful to compensate for small differences.
Laurence schrieb:That sums it up perfectly. The first time, I installed some mounting brackets incorrectly because I was trying to screw them in too fast. Not a big deal, but it really shows how important carefulness is.
A good tip is to check all installation steps one after another and not to secure anything too quickly
Hello everyone!
I really enjoy assembling Ikea kitchens – it’s a lot of fun! When installing the Metod units with appliances, I especially recommend starting with thorough planning. Make sure to get all the measurements of the appliances in advance (including cable length, hose openings, etc.) and design your kitchen so that at least the connections are easily accessible.
Quick tip: Leave the doors and drawers off during the rough assembly. This way, you can reach all the screws more easily and align everything better.
Be confident with the screwdriver and get to work – it’s definitely worth it!
FELOTAU schrieb:No wonder, that happens to everyone at some point! :-)
The first time I installed some brackets incorrectly because I was in too much of a hurry.
gabau31,
to answer your question thoroughly, you should consider the three main aspects: furniture assembly, appliance integration, and connections.
- Furniture assembly: When working with Metod, pay close attention to ensuring a stable and level alignment. Unevenness can cause problems later when installing the appliances.
- Appliance integration: The installation dimensions of the appliances are specified precisely in the instructions. Insert the appliances in the correct order to avoid difficulties accessing the fasteners later.
- Connections: For the stove and dishwasher, a proper electrical and water installation is required. Electrical connections should be carried out by a professional if in doubt.
Important: Be sure to use the included fastening materials. Additional brackets or screws can cause damage if they do not fit.
For additional information: When installing Ikea Metod kitchen cabinets with built-in appliances, precise measurements are crucial. The cabinet dimensions and cutouts must exactly match the specifications. Since appliances have standardized sizes, any deviation will immediately affect the fit.
- Measure the room carefully before starting, and check the walls for any unevenness.
- A spirit level is essential to ensure a level installation.
- Verify the positions of electrical outlets, as the kitchen layout may need to be adjusted accordingly.
- When assembling, initially fasten the appliances’ mounting points loosely, then tighten them in several stages.
This is especially important for appliances with heavy fronts.
