ᐅ How do I install IKEA Metod drawers with soft-close runners?
Created on: 3 Nov 2015 09:37
adiske
adiske
3 Nov 2015 09:37
I recently purchased IKEA Metod kitchen drawers and want to install them with the soft-close mechanism. I noticed that the included instructions sometimes lack details about mounting the soft-close feature, especially regarding the correct alignment and adjustment to ensure the drawers operate smoothly and quietly.
Could someone provide a detailed explanation on the best way to assemble the Metod drawers with the soft-close system? I’m interested not only in the basic installation steps but also in the technical aspects to watch out for (e.g., rail positioning, adjustment points, correct orientation of the dampers) and whether there are any special considerations when inserting the metal components.
I have some experience with furniture assembly, but with this combination of Metod boxes and soft-close slides, I’m unsure how to avoid potential errors.
Thanks in advance for any helpful tips and tricks!
TUELBA
3 Nov 2015 11:23
adiske schrieb:
Could someone explain in detail how to best assemble the Metod drawers with the soft-close system? I’m interested not only in the basic installation but also in the technical aspects to watch out for (e.g., position of the rails, adjustment points, installation direction of the dampers) and whether there are any special considerations when inserting the metal parts.
To address this topic specifically, here is a detailed overview of assembling IKEA Metod drawers with soft-close function:
- First, check whether the side rails and dampers used are specifically designed by IKEA for Metod. Different types of running gear are often offered.
- The slide rails are mounted on the sides of the cabinet carcass, positioned very precisely in height according to the instructions (IKEA usually provides a measurement in centimeters). A precise, level installation is crucial for smooth operation.
- The soft-close function works via a small gas or spring damper mounted at the rear area of the slide rail. Pay close attention to the correct installation direction arrow found on the rails.
- The drawer itself is fixed to the slide rails by side mounting clips or screws. You should feel a noticeable click when it locks into place.
- Adjustment points are usually located on the drawer front: height, side alignment, and depth can be adjusted using small screws or levers to ensure a flush front.
- Important: The damping only activates if the drawer is closed at least halfway; otherwise, the damper may not engage.
- Finally, open and close the drawer completely several times to ensure the soft-close mechanism works smoothly and the drawer does not bind.
Common issues like crooked slide rails or incorrect damper installation typically cause problems. If you can specify the exact model you are using, I can provide more precise guidance.
Bepolo
3 Nov 2015 17:44
TUELBA schrieb:
Important: The soft-close mechanism only works if the drawer is closed at least halfway; otherwise, the damper may not engage.
Definitely my favorite tip on this, or else you end up thinking the mechanism is malfunctioning! 😅
I would also add that when installing the drawer slides, you can take a somewhat hands-on approach—hook the drawer in early and open and close it a few times to check the movement. If it feels sticky, it’s better to realign it before finishing, as that really pays off later.
Also, don’t underestimate how important it is that all screws are properly tightened. With the softer materials used in IKEA-style cabinets, a screw can loosen just by pulling on the drawer, causing it to come off track.
Quick question: Did you use the version with white plastic runners or the fully metal slides? That can sometimes make a noticeable difference in how smoothly the drawer operates.
rotofra
4 Nov 2015 08:12
Bepolo schrieb:
Quick question: Did you use the version with white plastic runners or the ones made entirely of metal?
That’s actually a good point. The plastic runners are often easier to install, but with long-term use, the soft-close system tends to operate less smoothly. The metal runners are more durable, but it’s especially important to install them precisely, as even slight misalignment can disrupt the damper’s performance.
Regarding your original question, adiske, I would proceed step by step:
- Install the rail and damper: Make sure the running rails are clean and precisely aligned on both sides of the cabinet. Use a spirit level or at least a ruler.
- Properly insert the plastic stoppers: IKEA includes small plastic parts that prevent the drawer from being pulled out too far and falling—these must be installed accurately.
- Hang the drawer box: First, attach the rails to the drawer (usually two screws per side), then place the drawer onto the running rails inside the cabinet until it clicks into place.
- Adjust: You can adjust height, depth, and lateral alignment via screws on the front panels—these are usually hidden on the inside of the front.
- Function test: Open and close the drawer fully at least five times. If the damper doesn’t engage reliably, adjusting the runner slightly can help.
- Finally, check that all fronts close flush to avoid misaligned edges.
If the drawers are relatively large or heavy, it’s sometimes possible to expand the application options for the soft-close dampers on the runners by using additional stabilizers, which IKEA also offers.
Are there any special conditions in your setup, like uneven floors or lightweight cabinets? Then we could address those specifically.
