Good morning everyone, I am planning to install integrated lighting in IKEA Metod kitchen cabinets. I am especially interested in tips on how to properly and safely install LED lighting so that the power supply is neither visible nor intrusive. Additionally, I would like to know if there are recommended methods for neatly hiding cables and what electrical safety precautions I should consider. Are there differences between the various Metod cabinet models regarding the installation of such lighting solutions? I look forward to detailed advice, as I value the highest possible professional quality.
Regarding your question: The power supply should have at least 20% more capacity than the total LED wattage you are using. For example, if your lighting runs at 50 watts, you should select a power supply rated for at least 60 watts to allow for some margin.
Dimmable power supplies are specifically labeled as 'LED dimmable' and must be compatible with the control unit. With IKEA Metod, it depends on whether you use a separate control unit or purchase a set with a remote control. For pure LED strips without control units, you can also use simple PWM dimmers before the power supply. Important: Always ensure that the power supply and dimmer are compatible with each other.
Negutau schrieb:
If you want it really simple: IKEA sometimes offers suitable lighting kits from third-party providers for Metod Honestly, I find that overpriced and unnecessary. Sure, easy is always good, but standalone solutions often offer better quality. You have more control and can upgrade or customize the lighting as you like. Besides, DIY is part of the fun in projects like this.
Also, it annoys me how often IKEA products are forced into standard solutions instead of being truly flexible.
One last tip for integrating the LED lighting into the cabinets: it should be installed in a way that prevents glare—such as by using diffusers or matte covers. Additionally, switches should be tested before installation. If you include a power strip, be sure to use a residual current device (RCD) or ground-fault circuit interrupter (GFCI) to protect against electric faults. Properly securing the cables with cable ties to avoid loose connections is often underestimated.
