ᐅ How do I assemble Ikea Besta furniture with design-focused LED lighting?
Created on: 10 Nov 2022 18:37
disan
disan
10 Nov 2022 18:37
I am planning to assemble my new Ikea Besta furniture and would like to integrate design-oriented LED lighting to create a more modern and atmospheric overall look. Since Besta units are modular and flexible, I am wondering what the best approach would be:
- Which LED strips or modules are especially suitable for mounting on Besta furniture without affecting the structure or hinges?
- Are there any specific tips for wiring and power supply that take into account the often tight space inside Besta cabinets?
- How can I position the LEDs so they don’t cause glare but still look attractive—for example, behind doors, on the back panel, or inside glass shelves?
It is important to me that the lighting looks not only functional but also high-quality, without appearing too technical or makeshift. Maybe someone here has step-by-step experience or special advice on combining Besta furniture and LEDs.
Thank you in advance for your tips!
Sinan-meo
10 Nov 2022 20:09
disan schrieb:
Which LED light strips or modules are particularly suitable for mounting on Besta furniture without affecting the structure or hinges?
In general, I recommend flexible, self-adhesive LED strips with a low profile, preferably in cool white or warm white depending on the desired atmosphere.
The advantage of flexible strips is that they can be installed precisely along the inner edges of the Besta units without interfering with the hardware.
For power supply, I usually use an external power adapter placed outside the furniture. Ideally, the wiring is routed through the back panel openings to keep it out of sight.
It is important to measure the hinges and doors before installation to ensure the LED strip does not obstruct any movement. Some users also incorporate small connectors to make it easier to replace the modules if needed.
Finally, I recommend choosing dimmer-compatible LEDs to allow for adjustable light intensity.
klo40
11 Nov 2022 09:46
Here is a structured installation guide for combining Ikea Besta furniture with design-oriented LED lighting, especially helpful for beginners:
1. Preparation
- Fully assemble the furniture to determine the exact placement of the lighting.
- Measure the interior dimensions and cabinet doors to establish space requirements for LED channels and wiring.
2. Choosing the LED Lighting
- Flexible LED strips work well paired with aluminum profiles with opal covers, which ensure even, glare-free light.
- For glass shelves, LED rails with magnetic mounts are ideal as they are easy to install and adjust.
3. Installation
- Always mount LED strips or profiles in easily accessible locations, possibly centered on the back panel or under shelf boards.
- Avoid installation near hinge areas to prevent pinching or damage to the LEDs.
- Route cables through drilled holes or existing openings.
4. Electrical
- Use appropriate power supplies with sufficient wattage, installed outside of the furniture.
- Optionally install dimmers or remote controls to flexibly adjust the lighting mood.
5. Final Test
- Check all connections and test the LEDs before permanently securing everything.
Tip: Avoid sticking LED strips directly onto painted or high-gloss surfaces, as removal may cause damage. In these cases, profiles with clips or screws are better.
CHENFAR
12 Nov 2022 14:28
klo40 schrieb:
Avoid installation near the hinge area, as it can cause the LEDs to jam or get damaged.
This is an important note. Additionally, I would like to mention that integrating LED lighting in Besta systems is best planned using LED strips that are compatible with IKEA’s internal cable channels or can be routed through simple drilled openings.
For the power supply, I recommend low-voltage systems (12V (12V)), as they are safer to use and can easily be combined with dimmers or controllers.
If design orientation is a priority, using RGB LEDs with tunable white (adjustable color temperature) is worthwhile – this allows for very flexible adjustment of the lighting mood and adds aesthetic value to the furniture piece.
Regarding glare: the choice between opal or clear diffuser profiles is crucial. Opal diffusers scatter the light and prevent harsh shadows, which is especially beneficial for glass shelves.
One more tip: make sure not to leave cabling visible, so the design appearance is not compromised. Use interlocking points of the Besta furniture or concealed channels for this purpose.
