ᐅ How can you identify overload in a KALLAX before it breaks?
Created on: 9 Oct 2021 18:37
naeldeo
naeldeo
9 Oct 2021 18:37
I am currently looking into the question: "How can you recognize an overload in the KALLAX shelf from IKEA before it leads to a break or visible damage?" I already have a few KALLAX shelves in use and am curious about the signs that indicate a critical load. I am interested in both visual indicators (e.g., deformations, cracks) and other signs such as noises, unusual movement of parts, or other structural abnormalities that can help detect an impending overload early. Perhaps there are also practical experience or specific load limits to keep in mind?
I look forward to detailed assessments from the community, ideally with practical advice on how to prevent a break.
MUMENAR
9 Oct 2021 19:12
naeldeo schrieb:
What are the signs that indicate a critical load?
I would generally question the topic a bit more: The KALLAX is often underestimated as a shelf in terms of its load capacity, but this depends heavily on the type of use and also on the installation.
In my opinion, signs of overloading are not always clearly visible. A slight creaking or cracking under load can be an early warning sign, as can visible sagging of individual shelves. However, slight sagging is not necessarily a problem; the material naturally flexes.
It is also important whether the shelf wobbles or loses stability. This can indicate screws or brackets coming loose. For me, the key is to distinguish between temporary load and permanent overload – the latter leads to material fatigue and ultimately to failure.
I would specifically check whether the connections between the shelf parts are still tight and look out for stress cracks at the edges. Evidence that someone continues to use the KALLAX despite overloading often shows in warped side panels with small fractures.
Are there any experiences here regarding at what weights or volumes problems begin?
BEMAU
9 Oct 2021 20:44
MUMENAR schrieb:
For me, it is crucial to distinguish between temporary load and permanent overloading
I can only agree with that. KALLAX shelves are mostly made of compressed fiberboard (particleboard) with a melamine coating. Here, the long-term load limit is decisive for the service life.
Specifically: With a permanent load of about 13-15 kg (29-33 lbs) per shelf, the panel will fatigue over time. This first shows as a visible sagging, which increases over time. At the latest at this point, you should reconsider the load distribution.
For early detection, I recommend the following checks:
- Regularly inspect the vertical side panels for cracks or chipping at the edges.
- Watch out for loose or warped fasteners; screws and dowels can loosen over time.
- A faint creaking noise under load can indicate material stress and should be monitored closely.
Important: The static load specifications from IKEA are only rough guidelines; depending on usage and load distribution, the effective load capacity may vary.
In summary, regular visual and functional inspections are recommended, along with a maximum load of about 15 kg (33 lbs) per shelf to prevent damage.
tutan
10 Oct 2021 08:23
I think it’s okay to relax a bit when it comes to overloading KALLAX 😉. Of course, the material isn’t indestructible, but even small measures can help prevent breakage.
First: Don’t store everything just in the middle of the compartment! Distribute the weight more evenly to avoid pressure points spreading too much.
Second: A slight crack or creak when placing heavy items isn’t an immediate cause for alarm. These noises often come from the material adjusting or settling. However, if it happens regularly, sometimes accompanied by visible sagging of the shelf and loose screws, it’s better to rearrange items or reduce the weight.
Also: If the shelving unit wobbles slightly, don’t panic right away. Often, simply tightening the screws is enough to fix the issue and everything will be fine again. 😊
My tip: Just test how much you put in. It’s better to check more often than to overload one side. Better to have a few extra books in life than on the shelf 😉
flota
10 Oct 2021 10:07
tutan schrieb:
A slight crack or creak when placing heavy items doesn’t necessarily mean immediate danger.
That is correct. However, such noises should be monitored carefully as they can be early signs of developing material fatigue.
Additionally, there is a simple method to check if the shelf is overloaded: attaching a vertical level to the side of the shelf and observing a noticeable continuous deformation across the shelf panel indicates that the load capacity is being exceeded.
Another point: the static load capacity is usually specified for an even distribution. Concentrated loads on a small area (e.g., heavy decorative objects placed pointwise) can damage the particleboard more quickly.
In short: besides visual inspection and tactile feedback (noises, wobbling), it is advisable to distribute the weight evenly on the KALLAX and observe the load limits proactively—this helps prevent long-term overloading.
